Aussie work Van
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Got the van out of the workshop for the first time over the weekend, drove out under its own power without issue, few errors to sort still on the ABS side, but otherwise almost everything else error wise is sorted.
I want to take it for a proper test drive but didn't want to give it a decent run till the bay wiring was wrapped, which on one hand is good because I won't damage anything on the other if I have an issue I need to solve will be tricky, but given the errors I have I believe the wiring is done.
Thankfully after wrapping I didn't generate any new issues, so that was a positive.
After getting it onto all 4 wheels it needs some lowering, but main focus is getting it on the road first then the modifications can begin! ImageImageImageImageImage
Sent from my SM-S916B using Tapatalk
2013 Caddy Runner- 66KW manual- 2005 SWB Converted to TFSI DSG in house - Quite proud of this :D
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Slowed down progress wise over the last few weeks with a couple of race meets I was prepping for in one of the Mini Racecars- but focused on getting some done in the small allotments of time available- I popped the dash back in, and some of the centre console bits and bobs bolting all the modules into their correct spots so I can take it for a proper drive without things flying all over the place.
I spent some time today also wrapping the washer bottle harness as foe wherever reason it had been stripped back and the bottle missing, so that will be a job to pop it back in before the bumper goes back on.
I need to also get a better head unit for the van as this stock one is apalling, and find out what speakers I can use to better the audio quality throughout the whole van.
Also discovered that the slip ring wasn't registering properly so moved the one from my jetta which I've had sitting in the yard, so when I fire it up next I'll give that a whirl ImageImageImageImageImage
axtx
Re: Aussie work Van
Post by axtx »
This has been an amazing read! Thank you for adding so many photos!
Would love to know your process behind wiring and how you went about knowing where everything goes :)
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
axtx wrote: Tue Dec 17, 2024 11:32 am This has been an amazing read! Thank you for adding so many photos!
Glad you have enjoyed the read- always like using pictures to demonstrate a bit of the story with any posts i do anywhere.
So the methodology i used towards the wiring was- i started out removing the engines and determining where the TFSI plugged back into the car on the donor EOS to then link back in- IE T94 on the ECU from the body and several other wiring connection points in the right hand side of the engine bay- from there because i knew that T94 also existed on the diesel caddy as a connector, i pulled all the wiring diagrams for both the caddy and the EOS, and proceeded to create a pinout in Excel, and laid the T94 out next to eachother in the spreadsheet, and then created a third table with conversion- saying the old caddy pin on T94 moves to where for the EOS TFSI ecu- this assisted a lot as a starting point but i quickly lost motivation just repinning the ecu. I naively thought that "Surely it will just be T94" but it wasnt the case, So to get the project moving again i decided to install the Engine and gearbox into the caddy to give me something tangible progress wise to see, and then determine which connectors were in the EOS that werent in the caddy and started stripping the Loom segments as pigtails out of the EOS and pinning them in as necessary using the wiring diagrams to create diagrams on the pins usage, where it needs to go and what pin on the connector its going to, depinning where i could, splicing extra wire in where needed and cutting where necessary.
Eventually i reached close to the end of what seemed like endless wiring- when i came into this project some people said that there was several hundred hours in wiring alone for the first time round, and i can verify that, but as a project i wouldnt change doing it myself at all, ive learnt a lot, and the best thing that i did was simply go- one pin at a time, and it makes it a heck of a lot easier to manage, as when you look at the project as an overall whole on the wiring side it is extremely daunting.
I slowly got faster with each pigtail i ran, with the last couple only taking me 30-40 minutes each to put in, but more time going into research to ensure that where i was reinstalling them was going to work for the caddy itself, again the diagrams and my spreadsheet being king- and for this build in future troubleshooting if theres any issues allows me to troubleshoot from what i did exactly as i tried to take notes on how i ran specific wires and where they are physically run in the loom/cabin/engine bay for ease of troubleshooting later.
Currently where i am up to is that i no longer have any errors related to the engine swap itself thankfully, i only have a few lights related to the ABS which is the usual tricky bit to sort out, so ill be working on that over the next little while to ensure that i can get it error free before it goes off to Engineering here in New South Wales ahead of registration- goal is to have it on the road in February with plenty more mods to take place after the registration period such as custom exhaust with catted downpipe, facelift front end, lowering springs and axle flip, rear interior fitout, and carpet in the front cabin area, plus any other little mods i find along the way.
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Well, its taken a while but there's been a lot of progress in the small areas, it's taken a while with a bit of beating my head against the wall, but we are nearly there!
Over the last few weeks I've slowly but surely been getting more and more of the old wrap off the van, the paintwork underneath is pristine which has been fantastic.
The hurdle ive been waiting to try and overcome is the errors with the ABS/ESP- all were pointing towards a steering angle sensor issue, so I spent a few hours today swapping different combinations of swcm, slip ring, angle sensor and calibration methods, and eventually discovered all that was the issue in the first instance was the security unlock code needed to be different, once done all errors were clear from the dash for the first time ever! Image
I also discovered a code about not reaching boost pressure, which thanks to a tip off from a mate said the divertors always go bad, so swapped one off my jetta which we stripped last weekend- the caddys one was indeed toast, so after replacement i took it for it's first drive, and what an awesome bit of kit now it's working properly!
Next I unfortunatelt have some research to do as I have a couple of Transient codes which everything is working fine but it's periodically losing communication with items from the ABS, so will be diving into that now ImageImageImageImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Again been a bit since any updates.
Over the last while it has been just ticking little odds and bobs off as I go. I have since taken it for it's first proper test drive being able to take it for about an hour drive unregistered on an Australian UVP for testing, that threw up numerous issues, one which ripped the ABS sensor clean out of the front left hand corner, the other a fuel pump controller line issue.
So since the last update I have done the following:
- Extended the fuel pump controller wiring to keep it in the cabin.
- coded the mk4 tail lights in properly
- coded out some of the monitoring of lights that clearly work but are now LED
- coded several other basic behaviours
- reassembled the entire dash setup
- removed the old rubber rear mat in the cargo area
- cleaned the floor
- installed dynamat in the floor and roof of the van
- replaced the rear shocks with some from our other van to get it past rego
- got the van engineered for Australian roads (big big one this one)
- booked in the blueslip for a registration check ahead of gaining registration
- installed 6R front callipers with new rotors and pads
- installed a new back right bump stop
- removed all the remaining wrap off the van
- new phone holder installed.
The next few steps are:
-getting the blueslip completed for registration
- registering it
- new head unit, thinking RCD330 or 340
- building a rear floor from marine ply and some carpet
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Oops forgot to mention what the issue with the ABS codes was- idiot me made a mistake with the wiring for the ignition pin on the ABS which caused it to be on permanently and never turned off, which drained the battery and also caused regular codes, once i figured thst out it was easy enough to resolve
Re: Aussie work Van
Post by stu_b »
Well this van is certainly keeping you on your toes !!
Once it's road legal and got your blue slip n registered u won't know what to do with yourself hahaaa
How do u plan to fix down the plywood ?
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
stu_b wrote: Sat Feb 22, 2025 11:48 am Well this van is certainly keeping you on your toes !!
Haha sure was, i think for the most part its sorted now- still had an issue with the interior lighting, discovered that one of the fuses was blown because the previous owner had tried to install a baton light in the back which overloaded it, so removed the baton light, and fixed the fuse, which solved that drama- and picked up a replacement rear handle garnish today for it to replace the damaged one.
Regarding fixing down the plywood, i simply used the existing mount holes for the tie downs which has it properly pulled down to the bed of the van nicely, if i need more tie-down points ill probably add some rivnuts through the bed and just make sure that they are water tight, then pull it down further again- we had a plywood floor we purchased for the 1.2 caddy years ago, so the one for mine was just traced and fitted, the other caddy we have had for nearly 8 years, and had engines, gearboxes, work equipment and everything in the back, never had a drama with the floor moving or insufficient tie down points thus far which is good.
BigbrainGee
Re: Aussie work Van
Post by BigbrainGee »
Epic build, I will be saving this as I just started my conversion. Well, nearly stripped the eos. Engines out, just grabbing the entire loom.
My caddy has no AC, obviously no heated seats,or cruise control. I'm hoping by swapping it all over from thr EOS it will work relatively easy without loads of coding or re pinning.
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
BigbrainGee wrote:Epic build, I will be saving this as I just started my conversion. Well, nearly stripped the eos. Engines out, just grabbing the entire loom.
Mine thankfully had AC, if you record and pin it in where appropriate you will be right for sure Image
If your going to do it, do it properly and splice the loom in, don't try do a loom swap as door locks are a pain in the ass to get working- mine when it fired up only had a few errors which were pretty easily traced in my splice Image
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Well, bit has happened over the last few weeks, the van is now engineered, and registered!
Now the little mods can continue, so new door handle on the back to tidy it up, also picked up a stock timber roof lining, and darker interior timber panels which will be great till I do the carpet interior, plus got a maxi side slide cover and cut it down and managed to make it fit my short wheelbase with a bit of fettling with an angle grinder and some clips Image
I still have a battery drain issue which I've narrowed down to something AC wise, what's not making sense to me though is it was good for weeks and as soon as I replaced the RCD 330 head unit it's become an issue, but its not the head unit draining it Image so something to investigate there.
Just picked up a Tig welder so going to learn how to tig so I can do the 3 inch stainless exhaust as well, plus need to get the oz wheels powder coated as unfortunately these Talledegas aren't round.
But 1500kms already down in just over a week of it being registered and other than those things there hasn't been a single issue, and has been awesome Image
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Very little progress over the last little bit, but a few odds and ends.
Head unit drama turned out to be RCD330 incompatibility with the gateway, tried the emulator and didn't work, so replaced the head unit with an eonon unit and its been great thus far other than a few Android auto glitches wirelessly.
Unfortunately whilst I put my facelift plans on hold, I think it might be on the cards sooner, as whilst headed out for a long drive for work the other morning I managed to hit a kangaroo, which dented the bonnet which hurt nothing but my inner OCD.
Also had my axle flip kit arrive today which was really exciting, unfortunately will be a few weeks before I have an opportunity to install it, but when i do ill have some reasonably new Sachs shocks and eibach lowering springs to throw at the front.
Otherwise the caddy has been running awesomely, already done about 5000kms since finishing the engine swap and getting it registered. ImageImageImage
MWMRacing
Re: Aussie work Van
Post by MWMRacing »
Again been a while since my last update- honestly been pretty trouble free driving, as I've now racked up 12,000kms on it since the initial build finished and I got it registered- ive been dailying it and what an awesome bit of kit!
This weekend just gone i finally got round to installing my retrofication axle flip kit, and a set of eibach lowering springs that were donated from my Jetta, they also happened to be attached to a far newer set of Sachs shocks, so in it all went.
The axle flip was relatively pain free doing the grinding, cutting and welding, but God I hate the uprights and how they pinch onto the shock Image front took my longer to do than the rear did.
I also managed to get a darker interior from a good friend on mine Mark who is also a member here, he bought a caddy as a donor for the engine so gave me free reign to get what I needed out of the caddy before it went to scrap, so alas all the darker interior panels were pinched for my van Image ImageImageImageImageImageImageImageImageImageImage
Barnetto
Re: Aussie work Van
Post by Barnetto »
What an amazing journey loved reading the story, not sure I’d have the nerve to tackle a project this big.
Keep up the good work 👍🏼
