Page 5 of 12
Re: Lego Caddy Camper
Posted: Wed Oct 18, 2023 12:46 am
by Gmancan1
Little more done to grill
Plan to smooth in where masking tape is and do gloss black to match grill
Posted: Thu Oct 19, 2023 3:07 am
by Gmancan1
Coming along nicely
This is just tape mock up
With the badge on
Posted: Fri Oct 20, 2023 4:46 am
by Gmancan1
Started to feel like Hell raiser
“Plastic welded”
Soild now to work the edges in and smooth
(Wee mock up the silver likes going red)
Posted: Fri Oct 20, 2023 10:15 pm
by Gmancan1
Stuck on badge choice
(The line will be taped Red)
Custom tdi with red behind (i have a caddy to match)
R badge with white sticker
Tdi with white sticker
(Its black below might keep and use gloss black vw badge)
Posted: Mon Oct 23, 2023 11:46 pm
by Gmancan1
Posted: Thu Nov 02, 2023 4:11 am
by Gmancan1
Little more done
Alot more grinding
Posted: Fri Nov 03, 2023 5:31 am
by Gmancan1
Top coat then sand flat and spray
Posted: Fri Nov 03, 2023 8:22 am
by Dwr85
Gmancan1 wrote:Little tester/teaser of plans for Bay ive a Cover coming to
Plan to make head look like pipe coming out his mouth or side his head
You didn't see this on a little green lupo and take inspiration from it by any chance did you?
Sent using Tapatalk
Posted: Sat Nov 04, 2023 7:44 am
by Gmancan1
Ive seen done on loads
Defo seen that lupo tho!
Seen on a mini too (was gonna do yo mine)
Nothing new under the sun
Posted: Sat Nov 04, 2023 8:07 am
by Brutus1989
Dwr85 wrote: ↑Fri Nov 03, 2023 8:22 am
Sent using Tapatalk
Another great white caddy van! How simple was the touran centre console? Do I need the front kick trims too?
Posted: Sun Nov 05, 2023 5:58 am
by Gmancan1
Easy buddy just screw old off no your caddy ones should be grand
I do like the white doesnt take much to set off
Posted: Sun Nov 05, 2023 6:01 am
by Gmancan1
Sorted the bit round badge was trying to fiberglass andbwas going to use filler but if it flexed it might crack so “plastic welded”
Smooth and paint!! Baby steps
Posted: Tue Nov 07, 2023 6:22 am
by Gmancan1
Alot more smoothing
But its one
Posted: Wed Nov 08, 2023 6:42 am
by Gmancan1
Mock up idea
Posted: Thu Nov 09, 2023 3:03 am
by Gmancan1
Used sander (forgot i had)
Helped loads!
Just need to fill the low spots then sand again see what happends
(Btw noo idea what im doing)
