Wolfsburg Caddy (minor) Build
Re: Wolfsburg Caddy (minor) Build
Post by stu_b »
Do u think there is enough wiggle room to put 4way stretch carpet in there instead of the felt ?
Average_phil
Post by Average_phil »
stu_b wrote:Do u think there is enough wiggle room to put 4way stretch carpet in there instead of the felt ?
Yeah I’d say so. I think I will double up on the felt and see if that cures it completely. Will report back Image
Average_phil
So a break in the rain gave me a chance to get out and have another look at the whistling mirror situation.
I just had a good push and pull on all the mirror plastics and lo-and-behold I found the lower section of trim broken.
The outer fixing tab where the screw goes through had been snapped off but was still screwed in place so whipped the trim off, glued the tab back on, re-fitted it and took her for a drive….
Pleased to report - no more annoying noise!
Average_phil
Fitted the wireless charger today. Super easy. Just had to take a few tabs off the underside of the tray. Stuck it on and then made a little loom up to tag into the 12v cigar lighter wiring.
Picked up the rubber tray mat from TPS which has the wireless charging symbol on it (I got the part number reading through one of the build threads on here… I can’t remember which one as I think I’ve read pretty much all of them!) but thank you to whoever that was! Really finishes it off nicely.
Gmancan1
Post by Gmancan1 »
Thats looks smart!!
Average_phil
Gmancan1 wrote:Thats looks smart!!
Thank you mate
Post by stu_b »
Average.... what are the charging stats on that unit ?
Looks way smart 🤓
Was the loom available off the shelf ?
Average_phil
stu_b wrote:Average.... what are the charging stats on that unit ?
Looks way smart Image
Hi stu_b
324441536206
Here’s a link to the unit,
(*edited post as Amazon link doesn’t seems to paste properly. This is an eBay item number, same unit though*)
Comes with the wiring required. It’s literally 2 wires to power.
I modified the loom supplied by adding a little 4 pin Deutsch plug rather than using the scotch lock connectors sent with the unit. I find these a bit unreliable (and a bit brutal) you could always use a wago connector also which be simpler again.. So that’s the little loom I made up. I should have taken more pics but I was too keen to get it fitted.
Part number of the rubber mat is -
2k5 863 330 989
Again, the idea and part numbers were stolen from another thread on here so I can’t take any credit for it!
Cheers,
Post by stu_b »
Thanks for the info
I can't get either to work, maybe bc I am using eBay.com.au (Australia)
All good
Average_phil
It’s made by a company called INBAY. Have a google search for INBAY kit 3 coil wireless charger.
Average_phil
I’ve been having trouble with the side bars taking quite a battering over some particularly aggressive speed humps we have in work. It seems no matter how slowly I drive over them the van bottoms out quite badly.
I noticed since then that the drivers side bar wasn’t sitting as tight to the sill as it used to…
Drivers side -
Passenger side
I do like the look of them but decided to take them off anyway just so the van is more practical, and also it’s a pain in the butt to jack the thing up with them fitted.
The damage to the fixing bracket is substantial, so I was quite surprised.
Passenger side (as it’s supposed to look)
Driver’s side
Comparisons
Also if I lay the side bars side by side, the drivers side is bent which makes it about and inch shorter than the passenger.
As she now looks without them
Another job ticked off, although not a particularly exciting one! Didn’t take long though so have plenty of time left today to give her a clean!
Average_phil
Quick mod today, cable tied the bonnet release joint whilst I was checking the under bonnet levels
DW2207
Post by DW2207 »
That's a really good thing to do. It was one of the first I did on mine when I got it.
If you haven't already, put a piece of hose pipe over the spare wheel bolt threads if you have one
Average_phil
DW2207 wrote:That's a really good thing to do. It was one of the first I did on mine when I got it.
If you haven't already, put a piece of hose pipe over the spare wheel bolt threads if you have one Image
That’s a great idea. Thanks
DW2207
Post by DW2207 »
No worries Phil, it is documented on here, by other owners over the years buddy
