2009 caddy maxi with a supposed seat Leon engine and 6 speed with around 200bhp
So it was bought as spares or repairs, with apparently high oil pressure and supposedly if left running for too long then diesel mixes into the oil.
So with a little research my guess is the tandem pump?
Would a seal kit be a sufficient repair or get a replacement? (May get a second hand one first to see if that fixes it and if so maybe get a new one)
Any other ideas if it’s not the tandem pump? (Injectors?)
Now I’ve received it I had a quick look and it is wet underneath the tandem pump too
How would they have known the oil pressure is high?
And how will I know if the oil pressure is back to normal once fixed?
Thanks in advance for any help or insight!
