Camber shim kit
Freerider
Camber shim kit
Post by Freerider »
I had my caddy lowered a while back but have found i need a camber shim kit for the front .
It's a 16 plate 2l , so was wondering where is best place to buy
Re: Camber shim kit
What condition are you experiencing that you need to adjust the camber?
I'm not so sure a kit is common for your vehicle and shim form might not be an option based on the suspension configuration.
Freerider
Re: Camber shim kit
Post by Freerider »
Hi ..I got massive wear on inner part of front tyres
Freerider
Re: Camber shim kit
Post by Freerider »
It's got coilovers if that helps.
GregWalters
Re: Camber shim kit
Post by GregWalters »
You need a good alignment, not camber adjustment
Freerider
Re: Camber shim kit
Post by Freerider »
What and how do you mean by that dude ?
GregWalters
Re: Camber shim kit
Did you get the alignment done after lowering it?
Re: Camber shim kit
Is it just the inner edge of the tyre that's worn? Is so that's due to excessive toe out i.e. both front wheels are trying to move away from each other.
If the wear is even across the thread tapering to the inside, for example 5mm outside, 3 mm middle, 1mm inside, then you have a camber problem.
Excessive toe is often mistaken for camber wear.
Get yourself an alignment with the toe set to parallel or even a little toe in.
