Steering rack/pulling & passenger door ele
Lee123
Post by Lee123 »
Hey, everyone
I’m needing a bit of advice I have a caddy 2013 maxi life auto
I’ve now replace the electric steering rack 3times the clunking hasn’t gone it’s pulling to the left, the traction control flashes on a couple o times then becomes static
Another issue I have is there is no electric coming into the front passenger door there is power at the pillar but nothing works on the door
Any ideas or advice would be absolutely appreciated
Hope everyone has a good day
Re: Steering rack/pulling & passenger door ele
Welcome to the forum.
Have you checked for fault codes on the steering rack, maybe something will point you to the problem.
Your door power should be simple to trace with a voltage tester, have you had the door card off?
