Engine not fully heating up
Dave_c85
Re: Engine not fully heating up
Post by Dave_c85 »
DeanWhit wrote: Fri Jan 12, 2024 10:04 pm Booked in for the 24th. I get the feeling it’s going to be an expensive one 😭
From memory I think I paid around 350-400 quid to get mine replaced, have to take a lot of stuff of to get access.
DeanWhit
Post by DeanWhit »
Update… just picked the van up from having the stat changed.
Work was done by a reputable garage and he showed me the part that was replaced. Even mentioned how much of a nightmare it was.
It’s still doing it 😭😭😭 F#$k
Javito
Post by Javito »
My 1.6 caye takes a bit too long to warm up too.. especially compared to my partner's 1.6 blue motion which warms up very fast. I first thought it was the thermostat but the pipes to and from the radiator stay cold until it reaches 90ish degrees.
A couple of days ago while playing with VCDS I realised my EGR is always 100% closed. It must have been accidentally deleted when I got it remapped. I say accidentally because I just went for a simple stage one tune. They must have chosen the "wrong" preset.
Might be worth checking if yours is working.
By the way, my DPF regenerates with no issues, mostly every 750km.
Sent from my MI 8 using Tapatalk
NZDubNurd
Post by NZDubNurd »
Is it DSG or manual?
DSG's have the DSG inline thermostat in the hose too.
BurariRS
Post by BurariRS »
Mine was doing the exact same. I saw a similar post a few months ago, and replaced the thermostat. Problem solved after a new thermostat.
DeanWhit
Post by DeanWhit »
It’s a 2.0l DSG
Davidmorris
Post by Davidmorris »
As above Dsg has 2 thermostats one in the standard place and a in line one in one of the hoses by the dsg cooler .
DeanWhit
Post by DeanWhit »
Which one controls the dash gauge? Surely it isn’t both?
DeanWhit
Post by DeanWhit »
DeanWhit
Post by DeanWhit »
Nearly half an hour ticking over after a drive of around 15 minutes.
Is your radiator hose (near the airbox intake) warm when the temperature is at this level?
If so, I'd suspect the thermostat you have had fitted is stuck open.
Sausage
Post by Sausage »
Pretty much every VAG diesel I have owned has been like this, the worst of which was a T6, as soon as winter hits they struggle to warn up and maintain temp.
DeanWhit
Post by DeanWhit »
Doc, if you mean this pipe then yes, it’s warm but the temp gauge hasn’t moved after a 10 minute drive. It’s a new stat so is there a reason it would/should be stuck open?
Parts fail, you get it all the time.
I hate to think the amount of times I've had components fail on fit.
Essentially, that radiator pipe should be quite cold until the temperature of the coolant is above the opening temperature of the thermostat. I believe the stat for yours is rated at 84°C.
skandz
Post by skandz »
My 1.6tdi doesn’t warm up properly in the winter.
May have to chuck a stat on it see if it makes a difference
