Coil light update
Mungo76
Coil light update
Post by Mungo76 »
So vans been plugged in and its says EGR valve faulty. The van had its injectors replaced and new MAF senor recently. Ive been quoted 850 to replace EGR is that a fair price?.
Ive read its a common issue with these engines along with injectors.
Can you still drive with a faulty EGR?
Is this going to be an ongoing thing?
2012 swb 1.6tdi bluemotion tech dsg. Blank canvas ready to mod. Kernow bys vyken 🏴‍☠️
jackel
Re: Coil light update
Post by jackel »
I believe you can have the egr mapped out .
Bahnstormer
Post by Bahnstormer »
You can have it mapped out but if it's failed even slightly open you'll have issues. If it were me, I'd have it removed, blanked off, mapped out and never have to worry about it again.
Mungo76
Post by Mungo76 »
How does that stand with MOT i read that its a fail if removed.
Depends on how ‘friendly’ your MOT tester is. As far as I’m aware, if it’s been visibly altered it will fail the MOT if the tester is rigid about the rules (the guy I use is)
I had mine replaced when it failed a few years back (£750 in Liverpool) Since then, I’ve had it remapped and it was switched off but left in place so it still looks right.
Might be an idea to talk to your MOT tester first….I was looking at EGR/DPF delete at first and was advised against it.
