Headunit Installation - Am I being thick??
jockefc23
Post by jockefc23 »
Trying to replace my standard HU with a new Xtrons Touchscreen one. Disconnected old one ok, new HU came with the correct size connector for the van.
However when I've plugged it all in, there is no power going to the HU at all (I've plugged the old one back in to make sure it isn't a fuse etc)
I thought this might happen however as from the look of where the power wires from the van are, they aren't connected to anything on the new connector. See the photos, I presume the brown and red/yellow wires are the power?
but then on the new connection they are just heading to a blank area (top left)
Do I need to move the power wires in the block, and if so how do I do this? Or do I need a different connection?
Thanks for any help
Nicklouse
Re: Headunit Installation - Am I being thick??
Post by Nicklouse »
You will need an adaptor to connect the head unit connector to the car connector. Common thing for most head units. You may also need to run cables from the fuse box as the VW unit uses CAN to turn on and off rather than an ignition live wire.
jockefc23
Post by jockefc23 »
Thanks, but that second picture is the connector that came with the headunit, it's connected to the van connector in that photo. This is the other side of it.
Also the headunit comes with a Canbus box that plugs into this connection unit.
Gary.8
Post by Gary.8 »
Have you connected the two pin plug with a orange and red wire.....? If so disconnect it.
jockefc23
Post by jockefc23 »
Like this one?
No I didn't attach that, don't even know where it would go to. It has a sticker on it that says "connect cable when installing low - version" - no idea what that means.
For clarity this is the complete connection module that I got with the headunit (with the can bus decoder plugged in)
And also the wiring diagram for the harness
Gary.8
Post by Gary.8 »
Going by the second photo at the start of of your post the yellow acc and red wire are not fully seated in the adapter.. so that might be the cause of the problem.
Looks like you have a Caddy4, in which case you have the new style Quadlock connection with power in a new position to the old Quadlock.
You can buy an adaptor harness to convert back to the old Quadlock to suit your new stereo.
jockefc23
Post by jockefc23 »
Brilliant thanks, I thought there was definitely something wrong there. Do you know where I can get one at all?
https://www.rcd330.co.uk/collections/al ... 16-vw-cars
Just the first one I found, no affiliation or idea of quality or if the price is fair.
jockefc23
Post by jockefc23 »
Excellent thank you for that, some of the ones I was looking at were considerably more expensive.
Strange that I need an adaptor to connect to my adaptor to connect to my van!?! Is that due to the fact that although my caddy is a 2015 plate, it's actually a different mk# from the 2006-2015 ones? Or is it just an oddity? Just thinking for if I try and do anything else to it.
Thanks for all your help people
If yours is a Caddy4 with composition or discover head unit, it will have the new style Quadlock connection.
Caddy4 is essentially a mk4 caddy but is built on the same chassis (2K) as the previous generation.
