2013 caddy tfsi swap
Shadow0364
New to the form wonder if anyone could give me a bit of insight I have 2013 caddy 1.6tdi and bought a 2006 mk5 golf Gti front end smash doing a engine swap like many others I know it bolts right in and the wiring is a pain what I want to know was would the ecu work with the modules in the 2013 also could I use the engine loom from the mk5 and body loom of the caddy any help much appreciated
BB13
Re: 2013 caddy tfsi swap
The Ecu will work with your van modules, you will need to have the immo matched on the ecu to your vans immo. As for loom, you will need to re pin the golf side of the bay wiring in to the caddy.
bandito
how did you fair up? just about to get cracking on mine.
bandito
update status?
STP
The original poster hasn't been on the site since 2024 mate.
Best Caddy & Transporter upgrade content on YouTube: DTETV
