Part numbers/links
nathanjones916
Part numbers/links
Post by nathanjones916 »
Just getting ready for a trip abroad and planning on taking a couple of used/spare injectors with me. From what I gather I need a stretch bolt, O ring, copper crush washer and clip for the fuel return pipe.
Don't suppose anyone has the part numbers for these or a link to the parts, just want to ensure I've got the right bits incase get stuck. Thanks
Sent from my SM-G970F using Tapatalk
Nicklouse
Re: Part numbers/links
Post by Nicklouse »
Have a look on LLLparts.co.uk
nathanjones916
Had a quick look on there whilst on break at work, looks a good site but may take me a little while to find the parts. Thanks though will definitely be trawling through it later on
benzina1
Post by benzina1 »
You can have a look at 7zap. There's pretty much all
corroded
Post by corroded »
Leak Off Pipe - 03L130235AF
Injector - 03L130277S
Seal Ring - WHT000884
Crush Washer - 03L130519
Screw - WHT003187
For the 1.6 TDI, I think is the right ones (got these part numbers from my VW service history)
On my document the last three all come under 'Seal Ring' but there's three different part numbers which if you look up seem to suggest different things. Might be a kit.
Have no mention of the clip though.
