White Caddy, actual work Van!
Re: White Caddy, actual work Van!
You'll get there, seems like a lot of electric gremlins. Wonder if your loom is damaged somewhere
I think it may be, the sparks reckons there are some anomalous earthing points on the van. I think it may have been messed with in the past.Exterior6357 wrote: ↑Tue Nov 26, 2024 7:58 am You'll get there, seems like a lot of electric gremlins. Wonder if your loom is damaged somewhere
So Car Sparks has given me the pictures as below:
Now I'm not 100% sure on this as a google search gives me a return for Indicator stalks and i was sure i was after a squib ring.
any ideas?
any ideas?
You need to click on the [Advanced ID] to get the actual SWCM part number, the number for the complete stalk set will work but you won't need the complete stalks and SWCM.
I'd bet on it being a 5K0-953-569 SWCM due to your caddy being 2014 without MFSW.
Thanks Doc,
The only function on the steering wheel is.... steering!
I'll give VW a call and spunk £400 on the part then...
