Anyone know what this actually does ?
sheepy92
Post by sheepy92 »
Whilst servicing van today noticed this sort of restrictor in the airbox is it required or can i remove itImage
Re: Anyone know what this actually does ?
The part number comes back as an "air flow straightener"
Used to apparently minimise air swirling and uneven air patterns for better readings
sheepy92
Post by sheepy92 »
gazza31112 wrote:The part number comes back as an "air flow straightener"
Interesting, i have since found out that it was placed in during the E189 fix as you said to ensure the maf gets accurate consistent flow seeing as the van is remapped cant see it making much difference
Gary.8
Post by Gary.8 »
It will probably throw up the coil light and a fault from the MAF if you leave it out that's if it was already in when you had the remap done.... this is what I found when I took it out even with the E189 rolled back.
sheepy92
Post by sheepy92 »
Gary.8 wrote:It will probably throw up the coil light and a fault from the MAF if you leave it out that's if it was already in when you had the remap done.... this is what I found when I took it out even with the E189 rolled back.
Left it out buddy and been driving all day, doesnt seem to of made a blind bit of difference i dont have a dpf etc so pretty much free flowing, not sure if its placebo but fuel consumption seems better see how it goes
Gary.8
Post by Gary.8 »
Fair enough but for me it only ever did it on a motorway trip.
PJD
Post by PJD »
I think it's your van's appendix.
