Golf plus
dubtubz
Golf plus
Post by dubtubz »
Any one tell me if front seats from a 2007 golf plus fit 2013 caddy
dubtubz
Re: Golf plus
Post by dubtubz »
Looks like I need to drill caddy base.do I cut off lugs and bolt in back and drill front holes in base or other way round
Re: Golf plus
Cut lugs off, offer the seats up, mark where to drill front holes, remove seats, drill holes, bolt seats back in
dubtubz
Re: Golf plus
Post by dubtubz »
gazza31112 wrote: Wed Feb 26, 2025 10:46 pm Cut lugs off, offer the seats up, mark where to drill front holes, remove seats, drill holes, bolt seats back in
STP
Re: Golf plus
Post by STP »
Or get touran bases and just bolt the seats straight in with no drilling or cutting.
dubtubz
Re: Golf plus
Post by dubtubz »
Been looking into that to.breakers are looking for €90 plus just for bases
STP
Re: Golf plus
Post by STP »
The cheeky bar stewards get to know what's popular eh, then crank the price up.
dubtubz
Re: Golf plus
Post by dubtubz »
STP wrote: Wed Mar 05, 2025 3:29 am The cheeky bar stewards get to know what's popular eh, then crank the price up.
Just greed isn’t it.They only end up in a cube most likely
STP
Re: Golf plus
Post by STP »
Absolutely. Greed is everywhere now. After lockdown, lots of folk turned into ar.se ho.le.s
That hasn't gone away unfortunately.
God help the good people if the world ever ends up like "The Last Of Us".
dubtubz
Re: Golf plus
Post by dubtubz »
Do you drill the seat rails or the caddy H frame
Re: Golf plus
The h frame, the base
Re: Golf plus
Post by stu_b »
Hey Gazza
Don't suppose you know the weights or dimensions of the Touran seat bases by chance ?
Tks
dubtubz
Re: Golf plus
Post by dubtubz »
gazza31112 wrote: Tue Mar 11, 2025 9:29 pm The h frame, the base
On front of h base the welded support in channel is in the way off putting locknut in.
dubtubz
Re: Golf plus
Post by dubtubz »
Is it better to bolt to front of h frame and drill rear
Re: Golf plus
Stu, Iv only played about with my standard caddy ones mate, mine are approx 500x550mm and under 4kg each at an absolute guess Image
Dubtubz I bolted the fronts in the original holes then drilled the rears, sorry mate iv just seen in my previous post i said I drilled the fronts, that was my mistake!!! Was definitely the backs as iv used the original welded threads for the front, Iv just gone to check! Apologies mate!
Just took some pics of the backImageImage
