Vw caddy 2k 08 SDI starting problems
caddybat
Post by caddybat »
Hi
Big problems starting my van. It will not start then will start after a while of turning over it will go.
Any ideas please.
Regards Chris
Matt50
Re: Vw caddy 2k 08 SDI starting problems
Post by Matt50 »
I have a similar issue on a 1.9tdi . Have to turn the key on and off a few times before the relay kicks in and glow light comes on. Had a load of stuff changed . Relays fuses . Fuse box ingintion control. Still no joy .
Did you figure out what it was on yours .
STP
Post by STP »
The 1.9 TDI engines had a known issue where the injection pump would draw in air and empty the fuel line back to the tank, I had to fit a hand bulb to my Audi to prime the pump, I can't remember if I ever got to the source of the air leak but it was likely the o rings in the fuel line connectors. It was a long time ago but no doubt the design is the same.
Low fuel pressure causes the same difficulty in starting so it could be that which is wrong.
My DPF Monitor thread: DPF Monitor
