Touran doors cards and inserts
ClintK
Post by ClintK »
Hi all. Brand new to this forum and also to the world of caddy’s.
I have a 2015 swb Highline.
I have purchased Touran door cards and inserts if needed.
My question is my van has electric windows. Will they simply plug into the Touran switches? Or do I need to do something else?
Thanks for taking the time to read.
Clint
Updown789
Re: Touran doors cards and inserts
Post by Updown789 »
Yes the switches should be the same
ClintK
Post by ClintK »
Thank you
STP
Post by STP »
The Touran drivers door has 4 switches instead of the 2 in the Caddy. (There are rare 2 switch Tourans out there but not many)
Jmanley
Post by Jmanley »
how did the conversion go mate? was it plug n play?
ClintK
Post by ClintK »
Still haven’t done it yet. It’s my next job. I have got a holy grail 2 switch drivers side thingy so hopefully straight swop
C Chis
Post by C Chis »
ClintK wrote:Still haven’t done it yet. It’s my next job. I have got a holy grail 2 switch drivers side thingy so hopefully straight swop
If the wiring loom from the door module to the door switches is from a 4 switch panel you’ll need to re wire it to suit the 2 switch panel.
STP
Post by STP »
The van should be wired for two switches, not sure if you can keep the original door loom.
Be4ny13
Post by Be4ny13 »
The 2 switch Touran door card plugged straight into and worked in my Caddy (including the flashing red lock light) but if it doesn't you can remove the door handle electrics and window switch from the Caddy cards and fit them into the Touran ones. Effectively giving you a Touran door card with Caddy electrics
