1.6 TDI 2011 MK3 cranking then stalling
hlee17
Post by hlee17 »
Hiya everyone I have an issue when trying to start my caddy it cranks then dies , it has a brand new battery in it. In the scan from vcds I've seen my front right abs sensor is bad so I'm going to change that tomorrow but didn't think that would cause a no start...
[youtube]https://youtube.com/shorts/zGJWtcH-FtU[/youtube]
Occasionally when it's been left for a while and I try starting there's a noise coming from the throttle body (clicking grinding sort of noise)
Here's the scan
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TK HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9977
Revision: --H43--- Serial number: 00000000000000 CVN: 77B2CBC2
Coding: 00254014030500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TK 003001
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 020B3F0F950F188BD7-8056
VINID: 9E606AAAA09BA92A02243183081897F224
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 R HW: 0AM 927 769 D
Component: GSG DSG AG7 411 9060
Revision: 00041014 Serial number: TFK01103160199
Coding: 0000020
Shop #: WSC 46546 001 1048576
VCID: 387F9DE74B53825B39-806C
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 31
Reset counter: 10
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:41:38
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 433C400D092B03FDC21102E7901BC081300000
Shop #: WSC 35110 377 08192
VCID: 75E154D3DCC13F33E2-8020
3 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:05:02
Freeze Frame:
Count: 3
Count: 14
Count: 20736
Count: 8193
Count: 36352
Count: 0
Count: 65024
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 201
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:03:51
Freeze Frame:
Count: 3
Count: 14
Count: 20992
Count: 128
Count: 41472
Count: 0
Count: 65024
Count: 0
00285 - ABS Wheel Speed Sensor; Front Right (G45)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 201
Mileage: 218881 km
Time Indication: 0
Freeze Frame:
Count: 3
Count: 14
Count: 20992
Count: 48
Count: 39936
Count: 0
Count: 64768
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000000002
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW32.rod
VCID: 3D718CF3AC71A773EA-8068
1 Fault Found:
9481200 - Refrigerant Pressure
B10AB F0 [00001001] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 218835 km
Date: 2025.11.06.
Time: 00:30:24
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 2K5 937 086 B HW: 2K5 937 086 B
Component: BCM PQ35 M+ 011 1044
Revision: BD011001
Coding: 481A583A8025F16B088800829400816403517288726F8560648000000040
VCID: 356194D39C417F3322-8060
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 01021 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 280311 05 54 0403
Coding: 0330ED
Subsystem 3 - Part No: 7N0 951 171
Component: DWA-Sensor 00 002 0205
Coding: 000000
5 Faults Found:
00907 - Intervention load Management
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 201
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 16:20:21
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
OFF
OFF
OFF
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 16:11:38
Freeze Frame:
Term 15 Off
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 199
Mileage: 218779 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:31:08
Freeze Frame:
Term 15 On
Voltage: 11.85 V
ON
ON
OFF
OFF
OFF
03156 - Sensor for Anti-Theft System (G578)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:00:04
Freeze Frame:
Term 15 Off
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
03266 - Control Circuit for Signal Horn
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 16:11:38
Freeze Frame:
Term 15 Off
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 L HW: 1K0 919 475 L
Component: PARKHILFE 005 1806
Revision: 00005000 Serial number: 0 263 004 450
Coding: 108101
VCID: 3B7582EBBA65A943D4-806E
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL004PN7E Dataset Number: 2KC003v____ 0221
Coding: 000000000000000000000000000000003055
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356194D394417F3322-8060
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AF HW: 5K0 953 549 A
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KCH0004P Dataset Number: 5K0953507AF D005
Coding: 188A060000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 74E769D7DFBB263BD5-8020
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0054646
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K0 920 975 A HW: 2K0 920 975 A
Component: KOMBI H20 0421
Coding: 481C00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2E53BBBF71174CEB63-807A
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 280311F2001004
Coding: 357401
VCID: 306FA5C763235A1B71-8064
2 Faults Found:
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 27
Reset counter: 241
Mileage: 218788 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:56:50
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 199
Mileage: 218779 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:31:13
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H20 0421
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6ADB77AF8D7FE0CB7F-803E
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 489FED273BB3F2DB49-801C
2 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
008 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 3467A9D7573B663B15-8060
2 Faults Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.1 V
PD
Temperature: 15.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
01316 - ABS Control Module
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 201
Mileage: 218881 km
Time Indication: 0
Date: 2020.03.29.
Time: 00:01:49
Freeze Frame:
Voltage: 11.75 V
DD
Temperature: 15.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 479DEE1B36ADFDA340-8012
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:39)--------------------------
------------------------------16 Faults Found------------------------------
Nicklouse
Re: 1.6 TDI 2011 MK3 cranking then stalling
Post by Nicklouse »
A lot of those codes have old error dates. I would wipe them after you have done the ABS though that should not cause it to stop.
STP
Post by STP »
As you have VCDS, check the fuel rail pressure and see if it's actually enough to run, should be 300 bar (ISH) at idle and if it's way less than that, it won't run for long when starting it.
As Nick says clear all the fault codes, any that are genuine will come back, check things like fuel pressure and cam/crank sync as these will both cause issues if not correct.
Both will generate a fault code if not right, that you can then find with VCDS and take it from there. Has the fuel filter been messed with? It could be pulling air.
mark2406
Post by mark2406 »
Did you ever get to the bottom of what caused this?
This is what mine is doing now.
We’ve ordered a fuel rail pressure sensor and new fuel filters etc.
