ABS pump wiring
STP
Re: ABS pump wiring
Post by STP »
Yeah clear the codes first.
Isthatacaddy?
Re: ABS pump wiring
Post by Isthatacaddy? »
Still no joy. Cleared the code and it comes up with the same message. Requirements for output tests not met.
STP
Re: ABS pump wiring
Post by STP »
Could be a faulty pump motor then, have a look at this page:
https://remanx.com/blogs/common-faults/vag-abs
Isthatacaddy?
Re: ABS pump wiring
Cheers STP I will hopefully get to have a look at it tomorrow and try and Check for voltages and grounds at the ABS plug. Re-check fuses etc.
Isthatacaddy?
Re: ABS pump wiring
Does anyone know the correct fuse locations for the ABS pump for a 2009 1.9 tdi bls by any chance? Just incase I have foolishly misplaced one when I have checked them. I don’t think I have, but just incase, it would be nice to rule it out?
STP
Re: ABS pump wiring
Post by STP »
As far as I know it's 4 and 25 mate, 4 for the controller and 25 for the pump. RHS. Hope this helps.
Sent from my moto g34 5G using Tapatalk
Isthatacaddy?
Re: ABS pump wiring
I dont have a fuse at number 4 but I am measuring 12.01 on a red/blue wire and 12.05 on a black/white wire. 2.58 volts on an orange/black wire and 2.4 on an orange wire
I also have a continuity reading between battery negative and a thick brown wire on the abs plug
Here’s a pic of my fusebox: https://www.dropbox.com/scl/fi/3o1bsdbt ... gyoft&dl=0
Re: ABS pump wiring
SB04 and SB25 are needed according to my PDF for a later ABS unit.
Pretty sure you will need a fuse in pos. 04
Isthatacaddy?
Re: ABS pump wiring
Just had a look in my 2016 2.0 tdi and that has a 20amp at position No:4 I would have thought that if I had mis-positioned a 20 amp one then it would at least be in that area. I may just have to try one and see what happens.
STP
Re: ABS pump wiring
Post by STP »
I would, it's needed for the controller and would explain why it won't do the pump test. In your picture you can see it's missing.
Zoomed in, you can see it has terminals so it's not a dummy position. It's meant to have a fuse.
Isthatacaddy?
Re: ABS pump wiring
I tried a fuse but it didn’t work.
STP
Re: ABS pump wiring
Post by STP »
Ok that's weird.
Isthatacaddy?
Re: ABS pump wiring
No worries, appreciate the help. Will have to get my thinking cap on . Cheers.
Re: ABS pump wiring
Fuse holder B SB1 and SB2 both 30Amp seem to be for ABS on a 2009. SB4 5Amp controls the Onboard supply control unit J519, so there should be a fuse there.
https://fuse-box.info/volkswagen/volksw ... 2010-fuses
Isthatacaddy?
Re: ABS pump wiring
So going by that layout, I am missing two 30 amps and a 5amp. There’s only 2 parties who have access under my bonnet. Me and the garage where it was last MOT’d. Interesting 🤔
