Looking to see what single outlet washer pumps people have used when doing away with the rear wash wipe?
Washer pump
STP
Re: Washer pump
I just code the rear out with Obdeleven. No need to change the pump. When you remove the rear wash option it disables the rear pump output so nothing happens if you happen to push the stalk forward and the front still works fine.
That's what most folk do.
- uins
Re: Washer pump
Hi guys
If removing the rear wiper, will this cause messages/lights on the dash?
STP
Re: Washer pump
No mate it doesn't cause any errors removing the wiper motor. If you don't code it out however, the pump will still run if you push the stick forward and squirt water inside the door.
A few of us used a sink tap blank kit from Screwfix, costs about 1.99 and seals perfectly. Comes in chrome or white and has a sealing washer. Exactly the size of the hole too.
You have to unbolt the rear door handle mechanism to get the wiper motor out, just be careful bolting it back up - I just loosened mine and was able to slide the motor out. Cannot be removed without doing that though.
Coding is pretty easy with vcds or Obdeleven. Just select long coding in body module (central electrics 09) for rear wash wipe "not installed" and bingo it's gone, no more rear wash action and no water will come out, and the front will still work fine.
- uins
Re: Washer pump
Ok thanks mate. I’ve seen the blank used but I think going to go with killallwipers and have it painted the same colour as the vanSTP wrote:No mate it doesn't cause any errors removing the wiper motor. If you don't code it out however, the pump will still run if you push the stick forward and squirt water inside the door.
davoc220
Re: Washer pump
My issue is the pumps pissing washer fluid out when it’s in use, as fail it’s not the pipes that are the issue, it’s the actual pump, was looking to kill 2 birds with 1 stone bud
STP
Re: Washer pump
Ah ok, not sure which pump is available with only one outlet, but there must be one for a vehicle without rear wash wipe
davoc220
Re: Washer pump
As far as I can tel, the Passat and A4 look the same, A5 probably as well, , wee trip to the scrappy to compare, turns out the ode had split as well from when I did the headlights , just as well it’s been wet since September lol
