Hi, new to this forum, be gentle if I'm posting in the wrong place.
I'm after some advice re ABS module on 2009 Caddy 2.0 SDI 70hp. The part number is 1K0 614 117 AC the issue I'm having is no fluid is reaching the near side rear. It's not a collapsed hose or kinked pipe, pedal is good, no fluid out of module to n/s/r.
It's not worth buying a new ABS module so loking at fitting a used part, if I soucre same part number will it be a straight swap? Can I use same part number from a Golf/Octavia/Tig etc without coding?
Any help appreciated.
Thanks.
Caddy ABS module uestion.
Goldfish666
