Page 1 of 2
Caddy DSG Gearbox Swap 104bhp gearbox- 170DSG gearbox
Posted: Mon Apr 02, 2012 10:01 pm
by Ollie370
I want to swap a 6 Speed DSG from my 104bhp 1.9TDI engine, and replace it with a 6 Speed DSG from the 2.0TDI 170bhp as it is much higher geared. Problem is I have heard that the 170 DSG box may have a larger input shaft. Have checked the flywheel part numbers and they are different on the 2.0TDI engine from the 1.9TDI engine.
Does anyone know if the 2.0TDI flywheels will bolt up to the 1.9TDI cranks?
Re: Caddy DSG Gearbox Swap 104bhp gearbox- 170DSG gearbox
Posted: Tue Apr 03, 2012 12:25 pm
by Dangee
I wouldn't of thought they would fit, I'm sure the gearbox is completly different aswell on the 1.9s and 2.0s
Posted: Tue Apr 03, 2012 8:50 pm
by Ollie370
The 1.9TDI manuals are 5 speed and the 2.0TDI manuals are 6 Spd, but that is the conversion that everyone is already doing.
Posted: Tue Apr 03, 2012 8:53 pm
by Dangee
But the boxes they are using are 6 speed 1.9 gttdi boxes so there the same, the 2 litre and 1.9 boxes and completly different shape and won't fit
Posted: Tue Apr 03, 2012 10:18 pm
by Ollie370
Oh dear... that has put a big spanner in the works!!
Posted: Tue Apr 03, 2012 11:07 pm
by Ollie370
Posted: Fri Apr 13, 2012 7:04 pm
by Ollie370
Might give it a go next week, see where we are at, there must be a way.........
Posted: Sun May 27, 2012 12:18 pm
by Ollie370
With all this nice weather have finally had the chance to have a mess about with the caddy.
Pulled out the 104DSG box and compared to the 170DSG box.
They look pretty much identical! Loom plug looks the same, as well as driveshaft flanges etc. Input shafts, flywheel splines all the same!
Old (knackerd) 104 DSG flywheel on 104 1.9 engine
New 170DSG flywheel on 104 1.9 engine
Flywheels look very similar. Splines, bolt holes for crank all match up. The only difference we could find was it was 4mm thicker around the outside edge, (where the internal springs are) but not in the centre. Am guessing this is because the springs are bigger for the extra power of the 170. The 1.9 and 2.0 flywheels have different part numbers, this is the only difference I could see.
170DSG box is 1.9TDI caddy!
Filled it up with oil as per filling instructions. That was it.... It just worked! No VAG com, no adaptions required. I was expecting to need to do some kind of adaptions with VAG com but it was totally plug and play.
Drives so much better! 5th gear is the 170 box i think is actually a little higher than 6th was in the caddy. But once you get into 6th in the 170 box... how quiet. 70mph at 2100rpm, rather than 3000rpm.... mmmm On the old private road.. 100mph is 3000rpm
Posted: Mon May 28, 2012 8:59 am
by Evs
Great work. Looks sweet. How much you pick the gearbox ip for?
Posted: Mon May 28, 2012 7:38 pm
by Ollie370
Evs wrote:Great work. Looks sweet. How much you pick the gearbox ip for?
Ended up getting it for £400 of the bay. Took a while before one came up for sensible money.
Anyone need a caddy DSG box?
Posted: Mon Jun 18, 2012 10:45 pm
by bri6942
Hi
where abouts are you located, i am in Cambridgeshire, needing a caddy gearbox for caddy tdi 1.9L 55 plate.
Posted: Tue Jun 26, 2012 9:26 pm
by Ollie370
In Poole, Dorset, got it on the bay at the mo, started at £500 to gauge interest
Posted: Fri Feb 08, 2013 9:31 pm
by Wayner007
Know this is an old thread so apologies.
Ollie or anybody what it the code on the 170 boxes? tried to find the info but having no joy
Found an MFM box but can't find if thats the right code 2010 2.0tdi
Posted: Sat Feb 09, 2013 1:15 am
by basman
Even a 140bhp 2.0 should be ok might do the conversion to mine if I keep it as it tops out at 115!
Posted: Fri Feb 15, 2013 1:02 pm
by Clements
Can't believe the ecu for the box runs the 170 box, I know it's the same principle but some of these electrics are too clever for their own good. Glad it works, ill know how to fix my mates 105 TDI golf when it goes!
Great thread and massive help for my vw knowledge (Hondas before :-)
