so i have a question for those in the know
Report this post
the 08 passat is on a change over , you will have to look an see if its the same ( look at gearbox end ) .rubikzcube wrote:well we had some serious flooding here in the south of england last week and it would appear that beeing low and driving through puddles over the speed of 2mphhas resulted in my van taking in water and killing my engine
so i have a question for those in the knowi will be replacing the engine and was wondering what everyone woul do? i have been offerd a bxe engine + ecu out of a 2008 passat 50k for £650 or a 2009 523miler out of a golf £1200 with six speed gearbox and all drive shafts ecu etc. any ideas what will fit onto excisting engine mounts or what will be needed in order to change engine from a diffrent vw group car?. any assistance would be appreciated, budget is flexible depending on outcome
i will be fitting so can keep cost down, im thinking this would be a good oppotunity to increase to big power
Report this post
yep i went through the flood and it sucked up through the the grillsmartuki wrote: the 08 passat is on a change over , you will have to look an see if its the same ( look at gearbox end ) .
if the mount looks the same as yours it will go in yes .
the golg would be the easy one the loom is pritty much like for like , on the passat its a bit longer in polaces , an shorter in others . it will go but some messing about , nothing heavy tho .
but the gollf is the better job for a quick turn round , an 6speed too .
once your one is out it would probly only need a conrod , did it stop due to suking up water an stop dead ?
you run it up since ? missrire ,, sounds like its clackety clackity ( piston slap ) type noise ?
its tdi 105hp standard but running around 150hp with the remapsmartuki wrote:well if its just for the ponys then its gona depend on the bhp of both then , if they are much of a muchness then the golf is easyer .
you can out an in in half a day , what id your van , tdi ,sdi ?
thanks, i think the golf also especially with six speed box and 136bhp as standardI.D.S. wrote:Sorry to hear of your demise. I did kind of pussy around in the floods,not sure what abuse the caddy can deal with. Are these from breakers next to me? Have to agree with what has been said about Golf engine being your best bet mechanical wise but as always the electrics are a different story.
should be out an in in the day then no worrys , only need the engine loom etc , but it should be the same as whats in yours anywayrubikzcube wrote: thanks, i think the golf also especially with six speed box and 136bhp as standard
just read back through your message no this engine is 5 min away from me in eastergate, west sussex through breakers called src salvagesmartuki wrote: should be out an in in the day then no worrys , only need the engine loom etc , but it should be the same as whats in yours anyway
