D866
Post by D866 »
Where did you get the door seals Chis? I fitted some generic ones but would get the real deal if possible.
C Chis
Post by C Chis »
[mention]D866 [/mention] from LLL Parts.
Part numbers
Volkswagen Door Seal, Outer 2K0837701, left hand side
Volkswagen Door Seal, Outer 2K0837702, right hand side.
£48.53 for the left hand side, I assume the same for the right hand side.
Delivery was almost as expensive at £31.31! Best to wait until you need a few bits!
Post by stu_b »
but no mention of thickness on LLL or eBay
this is my question.....
philsparky
Post by philsparky »
[mention]stu_b [/mention] the factory panels are ~2.6mm thick, with carpet about 4.5mm
2017 Caddy Trendline 2.0TDI 102ps, Reflex Silver
Post by stu_b »
@philsparky thank mate, hard to imagine someone cutting / making a piece of wood 0.6mm thick (2.6mm)
you almost double it with carpet
I am thinking to use thicker ply so I an mount stuff on it
cheers for the answer
philsparky
I only used the original panels so the genuine handle surround would "fit", I had to fettle it to take into account the carpet thickness too
Post by stu_b »
I think I would either have to router out the thicker panel or opt for the less attractive / non oem looking lanyard version or similar
If I was to router it out then the whole handle would probably sit flush if not countersunk
Much needed new set of falcons Image
@ Stu_b
@Stu_b I used 6mm (I think) ply on my rear door, plus carpet. Couldn’t get the handle to sit right and get the full movement on it. Also, the trim wouldn’t fit around it. Ended up mounting the handle behind the ply. It works, but doesn’t look quite as good .Image
kentra
Post by kentra »
Today I ordered stereo upgrade for my Caddy Maxi 2017.
I got my Caddy yesterday and I am not impressed by the sound quality.. :P
The stereo package includes GAS MAX S1-6D1 subwoofer with case specially made for Caddy. And a Match M 5.4DSP amplifier.
Can't wait to hear the difference! :D
VW Caddy Maxi 2.0 TDI 2017
Bahnstormer
Post by Bahnstormer »
Had to re-pin the chassis side of the Lambda sensor plug as the 1.6 and 2.0 are slightly different, then got the front suspension rebuilt and got the van back on it's wheels! :D Then drove it all of 15 ft :lol: . All that's left to do is fit the two new ABS sensors to the rear and it's MOT time.
mac12
Post by mac12 »
the swan fiend wrote: Fri Oct 20, 2023 3:42 pm @Stu_b I used 6mm (I think) ply on my rear door, plus carpet. Couldn’t get the handle to sit right and get the full movement on it. Also, the trim wouldn’t fit around it. Ended up mounting the handle behind the ply. It works, but doesn’t look quite as good .Image
What do you call those collapsible hinges that you've fixed to the door?
Ga33a
Post by Ga33a »
philsparky wrote: Wed Oct 04, 2023 12:36 pm picked up my parts from VW and fitted the interior handle on the wing door
Sent using Tapatalk
I wouldn’t mind doing this to my Caddy, do you have the details please?
philsparky
[mention]Ga33a [/mention]
2k0829309A 9B9 x1 Handle Mechanism
2k0829323 x1 Handle Rod
N90940000 x3 Bolts For Mechanism
2k0827699A x1 Outer Trim
7H0827947 x1 Handle Rod Lower Clip
2k0867611C x1 Rear Panel With Handle Cutout
it’s about £70 from the main dealer, possibly cheaper online.
