So.. made a start on fabricating my box for
the compressors, driers and air tank
Revision #3
WiP, folded, clamped and welding under way… it’s been a while since I’ve held a welding torch in my hand
After 2 failed attempts…
the final version c/w tank and air vents. Mrs C added
the bow as she couldn’t believe this took 3 days!
Installation in a couple of weeks under
the van, through
the load area.
Bracket for
the Grinds controller, alarm, BT module and power connection test fitted. Started pulling in
the power wires along with
the front airlines. Excuse
the mess, all hoovered prior to refitting covers/carpets
New power wire pulled in by removing
the soon to be redundant PTC heater power wire making it a breeze!
Test fit of
the control panel
Flexible conduit used to give mechanical protection to
the power wires as well as
the air lines. Airlines to
the front are of equal length to reduce
the risk of uneven transitioning of
the bags.
Nice little transition through
the scuttle after a slight mod to
the existing wire seal. Might change this as it looks a little out of place.
