Taddy TFSI
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
I think a possible plan is to find a Golf R VCDS scan, recode the VIN in my clocks to the same as that then use the code from the MK60EC1 on that car.
Only thing is Golf R is of course 4WD, really I think I should maybe try from Golf ED35 this must have MK60EC1
Taddy R Project - Engine running
viewtopic.php?f=13&t=19895
Re: Taddy TFSI
Aha.
So the ECU VIN doesn't matter.
Might as well have ECU and Instruments coded correctly and immobiliser on in that case.
Hit me up if you need it coded. ;)
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
Doc wrote:Aha.
You got the kit to do the VIN and immobiliser back on? Do you need van or just modules
Re: Taddy TFSI
I think I can do both cluster and ECU for you.
What ECU is it?
I have a EDC16 bench rig only at the moment but that could change.
If you are local, I'd call and have a spin. ;)
spacewalker
Re: Taddy TFSI
Post by spacewalker »
ECU is not important
can be with Immo OFF
Focus on proper VIN in a cluster, and proper ABS coding
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
Doc wrote:I think I can do both cluster and ECU for you.
What ECU is it?
Im near Bournemouth so not local.
I have found a autoscan here.
http://forums.ross-tech.com/showthread. ... irocco-mk3
This guy has a similar issue also coding, but we VIN numbers are there.
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
This still feels so wrong. I have to keep telling myself it's right every time!
Joe90k
Re: Taddy TFSI
Post by Joe90k »
Haha
Has anyone ever looked at you funny or asked if you knew you were putting petrol in your van? I would if I saw someone doing it I think..
Caddy Maxi Kombi 1.6 TDi 102PS in Deep Black Pearl
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
No one has said anything as yet, but I'm sure people have looked and thought it!
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
Finally got round to taking some photos. Paintwork could do with work.
Re: Taddy TFSI
Wow, that's quite a tasty van you've got there.
You got your ABS problem sorted too?
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
Cheers Doc, Not yet, wanted to actually drive it and get some miles on it. Still running with the Standard ABS module and TDI clocks. Was going to see if Dan has any luck with getting Golf R/Scirroco R clocks working, then look into it again later. Traction control still works with the TFSI, sounds lovely when it cuts the power, make some very nice noises.
Re: Taddy TFSI
AW sweet, I'd love a go some time.
I believe Dan's is running, I've to code in a cluster for him whenever his exhaust is finished.
Ollie370
Re: Taddy TFSI
Post by Ollie370 »
Doc wrote:AW sweet, I'd love a go some time.
Yes, would be good to know how that goes as it may help if you get it too work. I might try and go up to some shows this year so maybe meet up sometime.
gogsie
Re: Taddy TFSI
Post by gogsie »
Like that a lot. The front end goes well with the black, what splitter is on it?
