Its a MK5 edition 30 splitter grafted onto the toucan bumper and blended in.gogsie wrote:Like that a lot. The front end goes well with the black, what splitter is on it?
Taddy TFSI
Ollie370
Re: Taddy TFSI
Taddy R Project - Engine running
viewtopic.php?f=13&t=19895
- dubvan
Ollie370
Re: Taddy TFSI
Finally the weather is getting better. Just started to fit the Caddy life carpet and panels
sutton1001
Re: Taddy TFSI
Wow you is a genius! All them frickin wires!! Great van I bet it flys.
Ollie370
Re: Taddy TFSI
Custom Fabricated 3" Exhaust on the Taddy. Think it might be a bit noisy for my liking.
https://youtu.be/u0xrRNkFfsE
- dan@biali
rsjohn
Re: Taddy TFSI
Sounds great, any pics of the exhaust?
Ollie370
Re: Taddy TFSI
Only got some pics of it on the floor. I was trying to keep it stealth but think I am going to have to change it up a bit. You can't see the exhaust from the back of the van, it is following the existing route and is then slash cut towards the ground. The problem is because it doesn't protrude past the rear bumper you get loads of drone at motorway speeds which is really annoying. I was pretty sure that it would happen but wanted to try it out to keep it stealth. I will probably have to be modded to go through the back bumper which I was trying to avoid.
The backback elbow is not slash cut in the picture, that has now been cut.
- torque777
Re: Taddy TFSI
Sounds awesome
- dan@biali
Re: Taddy TFSI
Could you put a turn towards the side so it's still stealthy but exits out under the bumper if that makes sense. I've heard of droning issues when having the exhaust facing the ground. Looking forward to hearing mine tomorrow now!
Ollie370
Re: Taddy TFSI
Think I'm going to play around with some different backbones to calm the noise down. I built the van to drive, and with those noise levels its going to attract too much unwanted attention. Its just a getting a balance between the noise and exhaust restriction.
- V4NYU
Re: Taddy TFSI
I cant pm anyone yet as im new to the forum is there any chance you could share some of your knowledge on this conversion with me
jackel
Re: Taddy TFSI
Nice big kudos for having the balls to do all that mate.I remember putting an rs turbo engine in an xr3 was a mare this would blow my mind
Ollie370
Re: Taddy TFSI
What do you need to know?
VolkswagenRacing
Re: Taddy TFSI
Nice work.
The painted covers of the bumper grill will fit on the original touran bumper grils?
