My new Caddy 4 build thread
stan-the-man
Re: My new Caddy 4 build thread
Post by stan-the-man »
Finally fitted my reverse camera and led lights. Was shocked to discover this
Never removed the light lens and the car isn't 1yr old yet.
Also when removing the trim the bolts were rusted and sized resulting in this:
The threaded part is originally moulded into the trim itself.
Old original bolt on right, new stainless steel on left. Had the new ones greased up as well Image
dubber72
Post by dubber72 »
hi stan what model where your seats out of are they passat or tiguan
Maxi4life
Post by Maxi4life »
what an amazing build so far! love the roof, infact the only part of this van I don't envy is the price :mrgreen: awesome.
stan-the-man
dubber72 wrote:hi stan what model where your seats out of are they passat or tiguan
The seats originated from 2013 b7 passat first then I used b8 electric bases and frames to convert them to what they are now :)
stan-the-man
Had some free time at work so decided it's time to fit my new speakers and door cards Image
Prewired the mirrors for puddle lights and also fitted oem led light under the door card for extra blingImage
Adapters were made from MDF as the original speaker mounting is around 21cm diameter and oem dynaudio speaker is much smaller.
New door card fitted, matches the seats perfect!
Also added brushed aluminium window switches
ed1119
Post by ed1119 »
The seats, door cards, switches and lights look great
TheGardener.ie
Post by TheGardener.ie »
Amazing build and van Stan, can I buy it off you in ten years if you still have it?? :D
What lowering kit did you go for?
stan-the-man
Thank you lads! Image
It's the eibach kit I used :).
Considering getting 18" wheels now as well but just not 100% yet.
Also thanks to cyberman_uk idea I fitted alarm led on the passenger door card for extra blingImage. Had to run wiring from drivers door reg motor as the passenger one has the pin in place but it's not live.
There's a mark underneath to where the hole should be to make location easier. Happy days!
stan-the-man
Today I managed to fit one of the new touran 5T puddle lights into one of my mirrors.
Very pleased with end result.
There isn't much room in there as the light unit itself isn't the smallest.
Had to shave off the area to make the light flush with the trim.
Overall delighted!
tommyzooom
Post by tommyzooom »
Very nice indeed :D
Gaj69
Post by Gaj69 »
Hi Tommyzoom,
Your Caddy looks great and sits just as I want mine on it's 17 inch wheels, what kit have you used and who fit it.
Thanks Gaj 69
Gaj69
Post by Gaj69 »
Appolgies Stan-the-man my question was directed at you, not sure why I wrote Tommyzoom.
needforspeed
Post by needforspeed »
great build!
Bright Spark Auto Electrical
07947719580
https://www.facebook.com/brightsparkautoelectrical/" onclick="window.open(this.href);return false;
stan-the-man
Hi Gaj69,
It's the eibach lowering kit used :)
Gaj69
Post by Gaj69 »
Thanks Stan,
I understand 2 kits are available, a 35 and 45 mm drop, VW say they only supply the 35mm kit, I don't want to void any future warranty claim. Did VW fit yours and can remember what kit was fitted, a part number would be great.
Thanks Gaj 69
