My new Caddy 4 build thread
Sportvan
Re: My new Caddy 4 build thread
Post by Sportvan »
Another request for you Stan....
Do you have the part number for the steering wheel ?
And was it simple plug and play on the caddy4?
stan-the-man
Post by stan-the-man »
Cbaker9076 wrote: Hi Stan do you still have the part number for the touran puddle lights please thank you
Sure thing, it's:
510 945 291 and 510 945 292
stan-the-man
Sportvan wrote:Another request for you Stan....
Hey buddy.
My wheel is 5TA 419 091 AG E74
Yes all plug and play but I only enabled paddles Image.
Sportvan
Post by Sportvan »
stan-the-man wrote: Hey buddy.
Cheers dude.
I’ve found a 5ta 419091n e74 would this wheel work?
stan-the-man
That looks like ACC/DSG/Heated wheel so I would say yes matey. But there’s always BUT🤦🏻‍♂️Image
Rev “N” became “AG” in 2016 so in theory it’s exactly same wheel
Sportvan
Post by Sportvan »
Ah ok so that part is just a year ident then. Still learning all that stuff. Image
I suppose I should wash it first really if I want to treat it to something Image
stan-the-man
No really as they keep revising the part numbers randomly. I reckon we will never be able to work out how they do it.
Etka will correct the number if it was changed once you check the price screen
stan-the-man
Sportvan
Post by Sportvan »
stan-the-man wrote:Image
Thanks for your help Stan!
Well, I’ve ordered one off the bay of E’s so fingers crossed it works when fitted.
Is it just a case of ticking the box in VCDS or do I need to go a little deeper?
stan-the-man
My Ampire reverse camera failed few weeks ago. It seems it’s rubbish build quality and didn’t last very long but just over a year. The black body it has started peeling as well which looked very bad and I would imagine it should have lasted longer than that.
The reason I went for it was because I didn’t want anything cheap and cheerful and wanted something that would suit caddy grip moulding as there isn’t much room behind it and didn’t want to be cutting the door to fit one of the VW OEM units like polo 6c or scirocco.
It was a bad choice it seems :(
So I decided to start the research again to find a replacement and after a while I came across OEM Opel/Vauxhall Insignia reverse camera.
I decided to go for it and €60 and week later it arrived.
I had my concerns about its size as I haven’t seen one before but when it came I knew straight away that this should work.
This is how I placed it in the trim, right under the bolt mount beside the lock barrel.
Had to do some trimming but the trim is still perfect and unaffected. The camera sits perfect too as it has to plastic wings on either side so because the trim thickness is greater I used the sand paper drum on my dremel to shave some off and it clipped in place spot on.
So at the mo very happy with it as the picture is quite good and it looks like oem unit on the outside as well.
I chopped the big plug off and extended the wires so it can go through the grommet into the inside of the door.
Will post more pics here once I wash the vanImageImage
stan-the-man
Are you just gonna use it for DSG paddles and ACC? Without heating?
If so you just will need to enable paddles in the steering wheel. I didn’t try them without changing the setting so perhaps they’ll work without doing soImageImage
Sportvan
Post by Sportvan »
Acc and Dsg. Is there extra work needed for the heated part ?
stan-the-man
Yes bit more involved buddy. Need to marry two sliprings together + have heated seats installed
RKDesigns
Post by RKDesigns »
Stan can I built a camera easily at the rear and connect it to the oem wide(touch)screen unit in my Caddy 4?
Sportvan
Post by Sportvan »
stan-the-man wrote:Yes bit more involved buddy. Need to marry two sliprings together + have heated seats installed
Ahh ok, I’ve got heated seats. How difficult is the fiddling with the sliprings?
