JD's Caddy Build
- Liam
Re: JD's Caddy Build
making great progress there JD
Build thread here
Build thread here
- JD2k
Swapped out the long cheap iPhone cable I was using for an apple one and that's sorted it! Thanks guysWhitey wrote: ↑Tue Jun 26, 2018 2:10 pm Hopefully brooneyes solution will work. I found that CarPlay would drop out if using either usb extensions or cheap usb leads from the Headinit. I ended up buying a belkin usb lead which was only a couple of quid more than a cheapy. No problems since
- JD2k
Thanks Liam, getting closer to finishing things off on the inside. Going to try tackle painting the light grey trim and headliner next!
- Caddyluv
Never be finished there will always be another project.
- JD2k
- JD2k
Camping prep underway! New bed arrived today.. few little tweaks and it should fit like a glove
Need to sort out a split relay system for a leisure battery next
lewi_grf
Nice van, love the carpeted out back
- JD2k
JD's Caddy Build
Fitted some MK5 Gti pedals today... a lot of messing around trying to get the accelerator pedal in but they’re in! (Excuse the dirty mat)
Oddy8911
Seats are looking great
- JD2k
Another job ticked off the list
Audi S3 8V air vents fitted... not totally happy with the fitment but they’re in for now
- JD2k
Tomorrow’s job... connect up a 115ah leisure battery with a split charge relay kit.. then fit a 600W inverter
- caddychris2002
Where did you get the kit from palJD2k wrote:Tomorrow’s job... connect up a 115ah leisure battery with a split charge relay kit.. then fit a 600W inverter️
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Mods:
- JD2k
JD's Caddy Build
Hi mate, got the kit from Simply Split Charge.. they’ve got loads of different kits on their online store.
I went for this one after seeing it posted on the forum. It comes with everything you need, even a drill bit and screws to fix the fuse box. The instructions are really detailed and easy to follow
http://www.simplysplitcharge.co.uk/stor ... duct_id=75
- The polisher
wJD2k wrote: ↑Mon Jun 25, 2018 9:48 pm After a long wait these finally arrived from eBay.. Need to figure out how to connect the aux port as it’s got an input for a RCD310 cable.. The USB port also seems to disconnect my apple car play connection after a minute or so but there’s still power.. So a little tweaking to do but at least they look better than blanks
Don't know if this will help but I found that if I used an after market cable on my CarPlay USB it would cut out after a few mins then I was told that the CarPlay like if you use the original iPhone cable to plug in. ,I got a original cable and all works well now , just in case
Touran seats, Touran Console, Touran carpets, Touran Door cards, Spoiler, German Plates, RCD 330, carpeted and insulated, TDI Mats, Stance lowering Kit, VW Mk6 Steering wheel, T6 Steelies, Bargain Sunvisor, Bragan Roof Rails,Touran mirrors
Instagram:HG_Metal_Polishing_13
Facebook: HG Metal Polishing
www.hgmetalpolishing.com
Ireland
Ireland
- JD2k
Thanks, yeah I swapped out the USB cable I was using for the apple one and that sorted it
