Liams Mk4
Liam
Re: Liams Mk4
Post by Liam »
Been quiet on here of late had no funds to do anything to the van been saving like crazy and apart from paying off my mortgage i now have some extra money for mods
so has anyone any info on installing passat cc electric seats to mk4 caddy ? hopefully getting a set of leathers this week
do the airbag looms match ? is there much to installing a loom to operate the electric parts on the seats ? unsure if they are heated at present but il know later in the week they are full leather from a 2013 passat cc
Build thread here
Caddyluv
Re: Liams Mk4
Post by Caddyluv »
Your probably need Touran bases.
Liam
Re: Liams Mk4
Post by Liam »
any of the previous seats i fitted i just redrilled the standard bases so i may go down the same route i know they end up lower but im tall anyway so it suits me
Build thread here
Liam
Re: Liams Mk4
Post by Liam »
Build thread here
Liam
Re: Liams Mk4
Post by Liam »
collected the seats today and my touran bases and got all fitted this eve they look and feel class very very happy with them
Build thread here
barnes
Re: Liams Mk4
Post by barnes »
That looks great :D
barnes
Re: Liams Mk4
Post by barnes »
Did everything electrical fit with the new seats?
Barbel330
Re: Liams Mk4
Post by Barbel330 »
Well smart that mate.
Instagram: @y_5cuf
Liam
Re: Liams Mk4
Post by Liam »
barnes wrote: Wed Oct 17, 2018 9:09 pm Did everything electrical fit with the new seats?
no im waiting on stan to make me the looms to work the electrical elements on it but for now they are in and mostly connected
but i have an issue
i have an airbag fault on both seats and when i check with vcds it says airbag fault on both seats reading low resistance so i dunno now what the hell is wrong the plugs were different but until the looms arrived i soldered the original plug on to the airbag loom so i could plug them in and colours matched so i dunno whats wrong seats are like new so i doubt and hope that the airbags arent faulty
if anyone has any suggestions please get in touch or post below
seats are 2013 passat CC full leather with a 2016 mk4 caddy
Build thread here
Liam
Re: Liams Mk4
Post by Liam »
was almost asleep and i suddenly thought of the airbag plugs that were not connected - (i had left the seat connectors intact so when the wiring harness arrived it would be plug and play and had simply spliced into the loom behind the plug but didnt notice that the plug had this shorting terminal built in so if the seats unplugged it shorts the loom )
anyway i pushed some plastic in between the pins to isolate it on both seats and ran vcds again and job done lighta gone out ImageImage
Build thread here
Jojo81
Re: Liams Mk4
Post by Jojo81 »
Love these seats. too bad theýre barely sold seperately and only with the heatet rear seats and passat door cards as well... that makes them a bit more pricy than :(
Liam
Re: Liams Mk4
Post by Liam »
Jojo81 wrote:Love these seats. too bad theýre barely sold seperately and only with the heatet rear seats and passat door cards as well... that makes them a bit more pricy than :(
yea it left them expensive but sometimes you just need to buy what you want even if its at a price you dont like so much 🤣
Build thread here
Liam
Re: Liams Mk4
Post by Liam »
pedals arrived today from ebay seem good quality no fitment issues managed to scratch and dent the accelerator pedal cover when trying to squeeze the clips on itbwith anpipe grips but luckily theybare made of stainless steel so i managed to remove it and smooth it back out with a hammer and punch and then redo its brushed finish with some steel wool
Build thread here
Liam
Re: Liams Mk4
Post by Liam »
busy evening
my heated elec seat looms arrived today with massive thanks to Stan-the-man
went to my parents to get using the shed as it was raining a little but it was too full to get in and i decided to just plough ahead outside in the drizzle it eventually stopped and i managed to get it all installed - the loom was absolutely spot on thanks stan and i eventually got it all completed and put back together
managed to strip a bolt when removing the drivers seat Image but managed to get it removed and replaced it with a good one
seats get pretty hot im impressed
wheels and suspension at the weekend with a bit of luck Image
Build thread here
Caddyluv
Re: Liams Mk4
Post by Caddyluv »
Well done for sorting it out. Toasty in the morning.
