Toffee delights
Lister79
Re: Toffee delights
Post by Lister79 »
No worries at all mate.
Dog walker
Re: Toffee delights
Post by Dog walker »
Hi there ? For you when you did the additional door seals did you go right round the door and it looks like about the 12mm size is that correct thanks for your time Gary
Lister79
Re: Toffee delights
Post by Lister79 »
Hi mate yeah right round the door with the join on the lower edge, remember to put drain holes through the seal at the front on rear otherwise you will collect water on your sill. I used 14mm D seal on mine.
Dog walker
Re: Toffee delights
Hi thanks for replying when you say on the rear do you mean the sliding door been looking at mine ( I have a maxi ) and not really sure where to put the extra seal have you got a pic of yours thanks Gary
Lister79
Re: Toffee delights
Post by Lister79 »
Hi mate, no on the front door (I haven’t done the sliding door ) but the front the rear corners on the lower section (where they touch the sill). I’ll try and remember to get some photos at the weekend as the van isn’t currently at my house.
Dog walker
Re: Toffee delights
Cheers appreciate that
james400
Re: Toffee delights
Post by james400 »
Looks as good as mine lol how did you find doing them with the lines ?
Lister79
Re: Toffee delights
Post by Lister79 »
Ha ha, the first one wasn’t too bad, I drew parallel lines on the rear foam which I aligned with the top of the handle recess. The second however was a pain in the arse trying to get the spacing to match the first. I think the vertical lines are off slightly, but I still need to put it back together so will see how it looks tonight. Cheers for pointing me where to get the factory material.
Taz6584
Re: Toffee delights
Post by Taz6584 »
Lovely van, the changes you've made are really done well.
james400
Re: Toffee delights
Post by james400 »
Lister79 wrote:Ha ha, the first one wasn’t too bad, I drew parallel lines on the rear foam which I aligned with the top of the handle recess. The second however was a pain in the arse trying to get the spacing to match the first. I think the vertical lines are off slightly, but I still need to put it back together so will see how it looks tonight. Cheers for pointing me where to get the factory material. Image
No problem mate we are all here to help each other out yes I had the same problem but in the end it come out looking good Image
Lister79
Re: Toffee delights
Post by Lister79 »
Drivers side finished, unfortunately vertical lines are in a slightly different position to the passenger side (was concentrating too much on getting the horizontal lines straight Image), but I still think it looks ok so I’ll be leaving it, and if you wave your phone about while looking at the photos you’ll never notice Image.
brooneye
Re: Toffee delights
Post by brooneye »
Looks good pal
Lister79
Re: Toffee delights
Post by Lister79 »
Cheers mate. Hoping to have it on the road 1st March, I’m both excited and dreading it as there isn’t a spec of dirt on it at the minute.
brooneye
Re: Toffee delights
Post by brooneye »
Is there much left to do on it?
Lister79
Re: Toffee delights
Post by Lister79 »
No not really A5 side skirts to fit, possibly windows to tint slightly then just little bits and continue with the polishing.
