Toffee delights
oofmeister
Re: Toffee delights
Wow, looks absolutely fantastic.
Sent from my Mi A1 using Tapatalk
- Lister79
Toffee delights
Thanks a lot everyone, I think I’m getting a bit obsessed with suede
More bits done over the last few days, thanks to @giddy for finding the part numbers for the black sun visors and seatbelt trims
. I’m pleased the sun visors are back in as I’ve been driving around for around 6 week without them, which isn’t ideal with the low winter sun. Too dark to get any photos of them re-installed now.
Roof tray done
W8 light and visor pivots repainted black
Ultra-Sonic trim, rear light and rear door catch cover
.More bits done over the last few days, thanks to @giddy for finding the part numbers for the black sun visors and seatbelt trims
. I’m pleased the sun visors are back in as I’ve been driving around for around 6 week without them, which isn’t ideal with the low winter sun. Too dark to get any photos of them re-installed now.Roof tray done
- Giddy
Re: Toffee delights
Looking good mate, like that you never stop improving! Did you retrim sunvisors yourself?
- Lister79
Re: Toffee delights
Cheers mate. No they were done by the bloke who did my seat belts, had them sat there for a while now but didn’t want to put them back in just to take them out again. Hopefully get the A and B posts done this week.
- Lister79
Toffee delights
Been pottering away with doing the remaining trims in suede this week. Also fit the proper bulkhead delete B-post trims. With the drivers side, as the non sliding door ones didn’t look right with the lower Caddy life threshold trim I have fit (due to rear seats), I went with ones that fit a sliding door model. Unfortunately this meant that the trim didn’t fit right at the top, so ended up cutting and welding a piece in to make it fit right (at least right in my opinion). Also trimmed the passenger side slightly so it wasn’t such a step sharp edge change. Had to redo the cab roof liner so the lower section was in suede as it just didn’t look right with the A-posts and tray against the Grey carpet.
Just need to make a new rear roof panel now to fill the gaps right (the carpet stuffed in is obviously only temporary).
- Azz03
Re: Toffee delights
Lister79 honestly mate your level of attention to detail is absolutely nuts mate got to hand it to you. Every time you upload something new I instantly know it’s going to be top notch.
- Lister79
Re: Toffee delights
Thanks a lot mate, got to keep things right.
- BillyGilly
Re: Toffee delights
Looks insane, quality work!
BillyGilly
2016 2.0 TDI Bluemotion: viewtopic.php?f=13&t=40889&p=341148#p341148
2009 2.0 SDI: viewtopic.php?t=40416
- Lister79
Re: Toffee delights
Thanks mate.
- Azz03
Re: Toffee delights
Lister79 have you got the proper side door steps for when the rear seat conversion gets done so you don’t have to cut the caddy ones to make them sit right. If so do you have the part number can’t seem to find it. Cheers
- Beaker2135
Re: Toffee delights
I’m going to have to stop reading your thread it’s confirming my inadequacy
Great work
Great work
- Lister79
Re: Toffee delights
@Azz03 the part numbers for the rear Caddy life Threshold trims (dark grey) are 2K0853369L71N and 2K0853370L71N, however if you’re looking to use them with the Touran rear seats they still need trimmed down slightly.
@Beaker2135
thanks mate.
@Beaker2135
thanks mate.
- Azz03
Re: Toffee delights
Lister79 cheers mate they look a lot better than the caddy ones trimmed so I don’t mind lol
Re: Toffee delights
Blimmin mental fell runners.....
Spot on again.....!
Spot on again.....!
- Lister79
Re: Toffee delights
Cheers Pat.
Well the 4am work body clock was still set this morning so decided I’d get the front door armrests rests fit that I had retrimmed in leather to match the seats. I think this is the 4th versions of these door cards now
but I’m finally happy with them so it’s all good.
Drivers side before
New arm rests fit
but I’m finally happy with them so it’s all good.Drivers side before
New arm rests fit
