Chawksey79
Re: Let the build begin
Post by Chawksey79 »
C Chis wrote: Wed Mar 18, 2020 4:32 pm Internal handle fitted today, much safer ImageImage no more lock-ins ImageImage
did your van already have the internal handle or did you retro fit?
Chawksey79
C Chis wrote: Sun Apr 12, 2020 2:35 pm So, today’s lockdown tasks were :
1. Get Eslawin working Image
2. Fit window graphic Image
where's the spoiler from seen a few companies selling different ones
C Chis
Post by C Chis »
[mention]Chawksey79 [/mention]
I installed the rear door handle, very easy to do. All the parts came from the dealer, cheaper than the kits on eBay, same parts, eBay guys just put a huge mark-up on the parts. There is a how 2 in the technical section along with all the part numbers. If you have a local TPS they will do the genuine parts cheaper than the dealers.
The spoiler was a cheapy from eBay, needed a lot of work to make it fit, turned out okay(ish) in the end.
C Chis
Let the build begin
Post by C Chis »
Today was a good day...
Modified my Touran centre console with the drinks holder and cover from a Golf
Cut the consoles with a Dremel and plastic welded in the Golf one
Heated and reshaped the plastic underneath to hold the cup holder nice and snug
After many fabric samples and weeks of waiting as they arrived and I went, nope Image I popped along to my local fabric shop and found some really nice black vinyl “leatherette”, cheap as chips and on the shelf, so bought a meter of it.
Part way through bonding the vinyl on
A little bit of heat from the old hairdryer...
Leave it to cure for a day(ish)
And then out with the old interior
A bit of a Hoover and clean, some dodo mat inside and the Touran carpets cleaned up
And a few hours later...
Really happy with how it’s all turned out!
Even reinstated the diffused red LED’s in the new centre console!
RLS will have to wait until tmr...
And the list continues and is getting shorter...
9. Dukes of Hazard air horns (so ‘70’s)
16. Touran/Tiguan instrument cluster - change of plan ImageImage
19. Lowering kit - all here along with new top mounts, wishbones and ball joints, waiting on workshop space to fit
23. Replacement colour coded rear bumper
24. Diesel filter cover
28. TV/DVD/multimedia unit for the back
30. Barn door to tailgate conversion and flip camera (long term)
35. Interior unlocking button for the side door
37. RLS
38. Engine/gearbox upgrade, power, more power... very, very long term
Papa Bear
Post by Papa Bear »
You need a new arm rest to match :D
Just done mine
Looking very nice 👍
Black
Marmite lover!!!
VCDS
C Chis
Post by C Chis »
Cheers bud!
I’m browsing retro retrims as I type...
Papa Bear
Post by Papa Bear »
I found a touran one, same colour leather as my new seats (or very close) £15 with rear cup holder and vent.
Black
Marmite lover!!!
VCDS
C Chis
Post by C Chis »
Just bought a black one from retro retrims
Tourans are rare up this way, mostly ones without the arm rest or a lovely yellow/beige colour
Papa Bear
Post by Papa Bear »
Was really lucky, found them in the back seat of a touran in scrappy. Someone must have needed the centre console to replace a damaged one and didn’t want the bits that went with it. Another win for me. Was onl6 looking for part of the cup holder :D
Black
Marmite lover!!!
VCDS
C Chis
Post by C Chis »
Awesome!
brooneye
Post by brooneye »
Done a cracking job mate
C Chis
Post by C Chis »
Thanks buddy! Pinched the idea from [mention]Lister79 [/mention]
C Chis
Post by C Chis »
Time to quieten down the van again...
Out with the old
New one ready to fit...
Old one ready for market place
And done! Just touching the bumper, going to leave it for now, thinking on swapping out the old bumper soon Image
And it’s sooooo quiet!
J_Con
Post by J_Con »
How did you find cutting out the centre console? I'd like to change the cupholder to one with a cover but I've never plastic welded before
Sent from my LYA-L09 using Tapatalk
C Chis
Let the build begin
Post by C Chis »
[mention]J_Con [/mention] hi buddy, wasn’t too bad, followed the pictures in lister79’s post and once cut and clamped together I used an old soldering iron for the welding along with cut off strips of the console for the welding rods, took a bit of time, but worked really well!
Like metal welding you need to get the plastic molten or the “welded on” bit won’t stick, discovered that whilst practicing
I practiced on the old cut up console first to get my eye in.
Couldn’t get the sliding cover to work in reverse though, however it actually worked out well in the end.
