Fan type washer jets
Grantek
Just fitted the fan type jets to my caddy 4 instead of the 3 individual spray type ones. I find the fan ones are hitting quite low on the windscreen.
Can anything be done with this?
- Papa Bear
Re: Fan type washer jets
There is a screw accessible from the outside to adjust them
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Katiecaddy
Where abouts did you purchase the fan type? Are they OEM if so do you have the part numbers?
- Papa Bear
I have the set from mine removed after I fitted the heated ones.
https://www.caddy2k.com/forum/viewtopic ... 20&t=44504
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Caddyluv
There are also heated fan jets which are good to.
Katiecaddy
Are the heated fan jets plug and play or do they require coding in?
- Papa Bear
Wired back to the fuse box, live when ignition on, no coding.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Katiecaddy
@papabear. Thanks for that. Wouldn’t mind the heated. We have those type on the Volvo and they work brilliant during the winter.
- Caddyluv
How to fit heated windscreen washers.
https://r.tapatalk.com/shareLink/topic? ... source=app
@katiecaddy
@katiecaddy
Katiecaddy
@caddyluv thank you for the link, much appreciated
- Caddyluv
No worries.
Maxi_Mike
I’m unable to open that guide. Does it contain PN for genuine fan type heated jets?
Did OP sort the Low jets?
Maxi_Mike
I can’t seem to access this yet. Is it just switched power, or pinned to the BCM?Caddyluv wrote: ↑Sun Oct 18, 2020 10:18 am How to fit heated windscreen washers.
@katiecaddy
Thanks!
- Javito
From that post:Maxi_Mike wrote: I can’t seem to access this yet. Is it just switched power, or pinned to the BCM?
Thanks!
Heated fan washer is 5M0-955-986C
Heated triple jet is 2K5-955-987A left
2K5-955-988A Right
Lots of cars use the same PN
https://vw.oempartsonline.com/oem-parts ... c3VsdHM%3D
They get power from the bottom row of the fuse box, meaning they're always on with ignition on.
Maxi_Mike
Fitted these now and like you say plugged into the back of the bottom row on the fusebox where there was a spare slot along the bus-bar
