Might change my mind sometime and go for blue
cheers the rivnuts is a good idea. i will have a proper look later at your build. you have done a lot of work.C Chis wrote: ↑Tue Nov 17, 2020 3:11 pm Hi, I have secured the plywood on with 4mm/6mm machine screws into rivnuts, makes the ply very secure and easy to remove and replace in the same position. The bike holder is also bolted through the plywood and a 150mm square of reinforcing 12mm ply behind. Also used large “penny” type washers to spread the load at the back.
I dropped the mag mount in favour of a short bungee with hooks to hook into a small “D” ring as I liked the cleaner look when the bike is in my van.
and awesome news on finding your air horns... just need to get them fitted now!
