I've come around to that idea after more research. I like the idea of doing it. Is it something you have done before? I don't have experience with it but would like the challenge of it.fishynos72 wrote: ↑Sat Jan 16, 2021 8:21 am I was a bit like that too
Realistically a facelift front bumper setup and some never taillights get you most of the way there visually
Show us your lockdown Caddy's
Sylvester
Re: Show us your lockdown Caddy's
- fishynos72
I've had bumpers off the front of both types of caddy, so that part is easy. If im understanding the posts on here correctly, it seems a small section of the inner front structure needs to be welded onto the earlier van to fit the later bumper and guard, then other posts say the small section of the front of the side window needs to be changed too. I'm not 100% on that yet.
The taillights are easy, find the part numbers to suit your needs light wise, then follow the instructions to re pin the plug for the new lights.
vag
Lock down escalated things
Facelifted my maxi along with engine freshen up/ 6 speed conversion and a 40mm drop, H&N front springs and reset rear springs.
Sent from my VOG-L09 using Tapatalk
- DeanWhit
That's a great job. Lovely van
vag
Thanks bud it's come along way from when I first got itDeanWhit wrote:That's a great job. Lovely van
- McCaddyGascar
Love that transformation. Front end looks awesome.
