Are u pleased with the ceiling lights ?
Are they touch ones also ?
Thank you! I am indeed, nice to have the remote for dimming if needed, 6 spot lights is a fair bit for a small van haha. And no not touch, turned on by my switch panel and also on remote if on at the switchstu_b wrote:Looking really good
Thank you3rdLeg wrote:Great work
Cheers! Nice one, I went for these from DST Automotive on ebaypaddythecaddy96 wrote:Looking really good so far! what roof bars did you go for? i got some caddy life rails the other day and just on the lookout for some bars now!
https://www.ebay.co.uk/itm/323790893967 ... media=COPYHi, i used some Stix-All in black. I thought it would be best to keep it completely dry under the solar panel, so i ran a bead all the way round and put abit extra in the recesses as i went around. Even the filled the fixing holes in each corner. (Not every solar panel has those)tippo wrote:Hi,
what did you use to glue the solar panel? Should it be a waterproof seal around the edges of the panel, or is some kind of drainage needed?
Cheers Johan
Doesn’t it just, i’m cuffed with them!Dixieland wrote:Amazing what a difference a set of decent wheels can make..............looks spot on mate
