Golf plus
dubtubz
Re: Golf plus
Looks like I need to drill caddy base.do I cut off lugs and bolt in back and drill front holes in base or other way round
- gazza31112
Re: Golf plus
Cut lugs off, offer the seats up, mark where to drill front holes, remove seats, drill holes, bolt seats back in
dubtubz
Re: Golf plus
Thanksgazza31112 wrote: ↑Wed Feb 26, 2025 10:46 pm Cut lugs off, offer the seats up, mark where to drill front holes, remove seats, drill holes, bolt seats back in
STP
Re: Golf plus
Or get touran bases and just bolt the seats straight in with no drilling or cutting.
dubtubz
Re: Golf plus
Been looking into that to.breakers are looking for €90 plus just for bases
STP
Re: Golf plus
The cheeky bar stewards get to know what's popular eh, then crank the price up.
dubtubz
STP
Re: Golf plus
Absolutely. Greed is everywhere now. After lockdown, lots of folk turned into ar.se ho.le.s
That hasn't gone away unfortunately.
God help the good people if the world ever ends up like "The Last Of Us".
dubtubz
Re: Golf plus
Do you drill the seat rails or the caddy H framegazza31112 wrote: ↑Wed Feb 26, 2025 10:46 pm Cut lugs off, offer the seats up, mark where to drill front holes, remove seats, drill holes, bolt seats back in
- gazza31112
Re: Golf plus
The h frame, the base
Re: Golf plus
Hey Gazza
Don't suppose you know the weights or dimensions of the Touran seat bases by chance ?
Tks
Tks
dubtubz
Re: Golf plus
On front of h base the welded support in channel is in the way off putting locknut in.gazza31112 wrote: ↑Tue Mar 11, 2025 9:29 pm The h frame, the base
dubtubz
Re: Golf plus
Is it better to bolt to front of h frame and drill rear
- gazza31112
Re: Golf plus
Stu, Iv only played about with my standard caddy ones mate, mine are approx 500x550mm and under 4kg each at an absolute guess
Dubtubz I bolted the fronts in the original holes then drilled the rears, sorry mate iv just seen in my previous post i said I drilled the fronts, that was my mistake!!! Was definitely the backs as iv used the original welded threads for the front, Iv just gone to check! Apologies mate!
Just took some pics of the back
