What the hell
Why on earth would this eyesore be mandatory ?
What's the reasoning ?
Surely a magnetic device would be better than drilling thru your roof - especially if your only visiting or travelling thru Spain....
Jase14
Glad you said what I was thinking
Sorry for the confusion - It is magnetic
Not a permanent fixture, it replaces the warning triangle as the new mandatory safety warning device for 2026+ in Spain.
It has GPS and IOT connectivity built in to relay position automatically to the road authorities in Spain when activated.
Edit: Sorry for the confusion !
I have edited the original post to add that it is for use in an emergency.
Oaky1965
Touran mirrors fitted.
Just need a couple more coats of paint on the plastic
- gazza31112
My first prototype of a new style led grill
Sent from my Pixel 9 Pro XL using Tapatalk
Ah, yes.
More crazy, mad, fun inventions from Gazza
Nice one
Nice one
@Petrev that's mad, full on but I guess good safety, esp at night if broken down etc
@gazza31112 why do u make these things look so simple yet to the average guy virtually impossible !! Looking forward to the end result n write up
- mirogo
Hi, is it possible to remove this grill from the starline bumper as well? MK4 Many thanksgazza31112 wrote: ↑Sat Aug 23, 2025 4:48 pm My first prototype of a new style led grill
- gazza31112
@mirogo hi mate, I believe the startline ones are moulded into the bumper...
- gazza31112
Attempted a doorcard retrim....
- caddy25
well today was productive started out like this back door was fully covered in carpet
so time to rip it all off and do it properly
all glue cleaned off took ages but came up very well then re covered the rear panel instead and re fitted it back onto the door
and the other door done aswell
''cross threaded is nature's loctite''
Andrew5
@caddy25 what did you use to remove the glue from the paintwork thanks
- caddy25
holts tar and glue remover i sprayed that on first let it dwell for a bit then used and old card to scrap the heavy stuff off did this about 3 times on both doors then used a microfiber cloth and some petrol to get the remaining glue off
- gazza31112
I was also going to ask this, done a bloody good job! Iv been trying with an adhesive remover, it's very slow going!
Andrew5
Niceone cheers I managed to get some overspray of the glue when doing my carpets
