Hi all,
This probably been posted a million times but has anyone tried one these leisure batteries or any of the other electrical items from Temu/Ali express
As always TIA
Temu Leisure Battery
mark2406
STP
Re: Temu Leisure Battery
I've bought replica window switches from AliExpress along with a lot of other stuff but never bought anything from temu. The stuff I've had has been good so far on everything.
mark2406
Thanks STP,
Some of the suppliers are uk based on there now, just weighing up whether these lithium batteries are worth a look.
STP
I have to say for something big like a battery id probably buy local or from a UK supplier.
jakemcc97
I wouldn't risk a battery from there.
I use AliExpress for a lot (great place to find VW electrical connectors etc) but you've gotta be realistic about what you're getting. If it seems too good to be true, it usually is.
PJD
Lithium ion leisure batteries have been known to catch fire, even from reputable suppliers due to faulty BMS. At least they will issue a recall if faults are found.
Some might be advertised as the safer Lifepo4 but I still wouldn't trust them.
For such an item I would go with a trusted UK supplier.
Rob.
I never use Temu but currently have a lithium battery made from Yinlong LTO cells from AliExpress, plus another using Fogstar cells with a JK BMS from AliExpress
What's the specs, amp hours etc and price of the Temu one?
rhyre
Qoltec Akumulator LiFePO4 12.8V/30Ah/384Wh
this one fits perfectly in side between wheel arches.
