Another White Caddy...
Scotscad
Re: Another White Caddy...
Did ur van not have tweeters in the top of the dash as standard? Iv got them in my mk4.
- Flog_TSC
Looks greatcorrigan42 wrote:Went to a local paint shop and got a can of 2k paint mixed up and it’s a much better match! Left over night to dry, then it’s time to polish and fit it all
Carpeted the roof and added some holes for some down lights, ignore the carpet bulging out I sorted that lol
Lovely and bright in the back now! Also wired a switch so I can turn them off when needed, will add a permanent feed to it in the future.
Carpeted bulkheads in now also, had a bit of a happy accident where I didn’t trim the ply floor enough for the bulkhead to slide in front of, but because of that the bulkhead now sits a little further back, and I can recline the seat much further back
Now onto making holes for the reversing sensor in the new rear bumper, was a bit scary, but the Sealey pdc tool I bought made it super easy.
Glad I bought the tool and didn’t just try to drill them, as it did a really clean job!
Not bad at all!
Getting the bumper and sensors into place however was a bit of a struggle!
Thank god that’s over
Painted sliding door cover installed
Rear door trim colour matched and fitted
Caddy life mirrors and painted side trim installed![]()
So glad to get rid of those awful side mirrors!
Where did you get the rear bumper from is it a repro one ?
- corrigan42
Nah it’s a startline model so there was no tweeters in the dash! Even if there was I would have moved them to the door as, the sound is much better compared to the stock ones that just bounce the sound off the windscreenScotscad wrote:Did ur van not have tweeters in the top of the dash as standard? Iv got them in my mk4.
- corrigan42
Got them off a guy off Facebook called carpanels4u which is an aftermarket painted bumper, super nice guy and really good paint work! Better than the front bumper I bought off ebayFlog_TSC wrote: Looks great
- Flog_TSC
Nice one cheers gonna change my maxi one to a mk4 one looks so much bettercorrigan42 wrote: Got them off a guy off Facebook called carpanels4u which is an aftermarket painted bumper, super nice guy and really good paint work! Better than the front bumper I bought off ebay
- corrigan42
Couldn’t resist the digi dash upgrade!
Easy install, but I had an issue were the van wouldn’t start, reseated the connector in the back a few times and all is good
Also got an android head unit with CarPlay and hdmi output, so I can feed the dash that signal, rather than screen mirror straight from the phone. Also wrapped the head unit surround in gloss black
HDMI out from the head unit works a treat!
Had to take the dash out at this point, as audio was also coming out of the tiny speaker in the new dash lol, removed the speaker and reinstalled the dash, all done
Door handles also done in gloss black
- Flog_TSC
Is the dash a tmg one ?corrigan42 wrote:Couldn’t resist the digi dash upgrade!
Easy install, but I had an issue were the van wouldn’t start, reseated the connector in the back a few times and all is good![]()
How is it ?
- corrigan42
I bought it from AliExpress but it’s exactly the same thing as tmg sell for half the price, keep an eye out for vouchers as I got it for nearly £100 off around Black Friday.
You’re just paying for the tmg name with their one, best place to get one would be through https://everest-vw.co.uk/ a little bit more expensive than straight from china, but he really knows his stuff and would sort any issues quickly.
I think it’s great, really customisable and brings the interior up do date!
the only downside is it doesn’t fit the shape of the dash perfectly, the curves at the top of the dash are miles off lol. Some people put strips of black adhesive foam there to kinda fill the gap, but it doesn’t bother me that much.
- Flog_TSC
Cheers for the info yeah I did think that I don’t understand how that tmg lot are doing so good the slap some paint and loads of bolt on stuff and claim limited etd pmslcorrigan42 wrote:I bought it from AliExpress but it’s exactly the same thing as tmg sell for half the price, keep an eye out for vouchers as I got it for nearly £100 off around Black Friday.
- Flog_TSC
Mines a mk3 caddy would it work ?corrigan42 wrote:I bought it from AliExpress but it’s exactly the same thing as tmg sell for half the price, keep an eye out for vouchers as I got it for nearly £100 off around Black Friday.
- corrigan42
Yep!
I've heard the mk3 might need a little trimming behind the dash to fit perfectly tho.
This is the one I bought, just be sure to select the correct year!
https://www.aliexpress.com/item/1005006 ... 1802WCkebZ
Only issue that's popped up after driving a few miles, is the "miles remaining" screen seems to be displaying the wrong number, looks like it's showing KM rather than miles... think this can be fixed via VCDS so will be giving this a go soon!
- Flog_TSC
Nice one may treat myself in the new yearcorrigan42 wrote: Yep!
- corrigan42
Just installed some ambient leds in the interior, 2 strips in the dash, and some footwell lights. Install was pretty easy and they look great imo!
Wired to a switched live from the drivers side fuse box, so they come on with the ignition
Also bought a cheap VCDS / vagcom cable and fixed the issue with the digi dash showing the “miles remaining” display in KM - just had to set the system to report that data in KM and now the dash display correctly
- corrigan42
Decided to tint the rear lights, I sprayed them a tad darker than I wanted, so I could wet-sand and polish them to a glossy finish.
Looks nice after a polish
They look even darker when not in direct sunlight like below, but the lamps shine through perfectly fine!
Also tinted the side repeaters
jakemcc97
Looks great! Some change from the standard van.
The digital dash is super tempting - will be keen to see how you get on with it. I saw some early feedback that dashes had been cutting out randomly, do you know if they've fixed that issue? That'd be the only thing making me go for one from a UK seller, AliExpress returns/support are usually excellent but sometimes easier to deal with someone more local...
Ambient lighting looks nice, any more pics of that install?
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
