Hey guys,
Just picked up an 07 1.9 TDI DSG caddy this week and it seems that when taking off from a stop the van wants to axle tramp/shudder. You can drive around it fairly easily to prevent it from happening. it's particularly prone to doing it when starting on an incline.
Any idea where to start looking for an issue? My first though is suspension bushings the 2nd and scarier thought is clutch packs in the DSG.
I did some searching but couldn't find much on it. Hoping someone can point me in the right direction.
Cheers guys
Shuddering/tramping under acceleration
son of eevil
Re: Shuddering/tramping under acceleration
There's several possibilities.
Your van has a DQ250 DSG gearbox which should have an oil and filter service on a 40,000 mile interval. Do you know if it's had it or is maybe due one?
The juddering can often be a symptom of a failed dual mass flywheel. Are there any strange noises in the area of the flywheel that might point to such an issue?
Tyre condition and tracking are another possibility, the maximum forces on your tyre are the initial take off from standstill so poor thread, misalignment or poor contact with the road due to excessive suspension geometry might be an issue. Are your tyres in good condition, has the tracking been checked recently?
Worn bushes on the front suspension are possible causes also. The track rod ends, wishbone front and rear mounts are all points where the geometry of the wheel might be changing as you take off from standstill. Have you had these checked or know of any replacement that has been carried out?
son of eevil
The dealer I brought it from claimed it just had a full service. I wouldn't trust him not to lick a shit flavoured lollipop though. When I pulled the air filter it hadn't been done.
I actually have the oil in the back and I'm waiting on the oil filter to come in so I can replace it.
Do you think poor service interval could cause it and would you expect it to go away after a change?
I just had new wheels, tyres and a wheel alignment done and so far no change. There was a 1.8 degree of negative toe on the left wheel, both are now back to 0.5.
I haven't checked the bushes yet but I'll probably get around to it tomorrow.
I've felt "slight" vibration at over 60mph but it's not consistent, nothing at idle either. Doesn't seem consistent with the flywheel but I'm not sure.
Thanks Doc for such an in-depth response!
Sent from my SM-G991B using Tapatalk
Definitely worth a gearbox oil change if you don't have the history or know if it's actually been done. The DQ250 is very sensitive to oil quality.
son of eevil
Excellent, I've heard that otherwise the DQ250 with the wet clutch is a very solid box and faults are not common.
(Why I held out for the 1.9 instead of getting the 1.6)
I know of several DA250 gearboxes working at over 400BHP without problems so you should be fine so long as it's cared for with regular servicing.
son of eevil
This van has always done this since I've owned it (5 years) and here are the things I have done over the years none of which have fixed the issue:
New passenger, driver and dogbone mounts (all were shagged)
New DMF (old one was rattling like hell)
New shocks front and rear
New tie rod ends
Swaybar droplinks
New tyres
Whole second hand gearbox
Whole second hand engine
Driver and passenger axles.
Control arm mounts and bushing
ball joints
The engine mounts, DMF, Gearbox, tyres, tie rod ends, drop links, gearbox, passenger side axle were all done in the last 2 months.
(The mechatronics unit in the old box shat the bed so I got a second hand gearbox with 140,000k's and I decided that while I had everything out of the way I'd put new stuff in hence why all the mounts bushings and rubbers were done at the same time)
I do not know what could possibly be causing this issue I really feel like anything that could cause it has been replaced but I must be missing something.
New tie rod ends
Swaybar droplinks
New tyres
ball joints
kobat79
My DA250 does what sounds like a very similar thing from take off. If you come on the power smoothly and gently it is fine, but if you go hard it can be very 'jerky'. The van has 233k miles and it's been like this since I bought it a couple of years ago. It's not been an issue so far and I just take account of it in my driving style.
It's been in the back of my mind to do a gearbox oil and filter change to see if that helps. Did you do an oil and filter change to either your original box when Doc suggested it, or indeed to the replacement box with 140k on it?
son of eevil
both old and new box have had fresh oil and filters
STP
Have you tried switching off the TC by holding the button down to see if it still happens? Maybe the traction control is a bit keen.
Have the anti roll bar bushes been done? Or try poly ones.
Best Caddy & Transporter upgrade content on YouTube: DTETV
