Splitpin
Posts: 349 Joined: Tue Oct 04, 2011 5:24 am
Post
by Splitpin » Thu Oct 20, 2011 3:56 pm
Yep
I just put it over the springs and started measuring! I clamped it using all the stock clamps while it's on the ramp to get the locations correct.
Please not I would not drive it like this as the axle could rotate! It will need steelwork adding but this is how I worked out the best location.
Note the shocks are removed at present for access.
vagnostics_ltd
Posts: 657 Joined: Sat May 07, 2011 6:45 pm
Post
by vagnostics_ltd » Thu Oct 20, 2011 10:26 pm
So how much lower did you estimate it would be?
azzatdi
Posts: 104 Joined: Wed Nov 17, 2010 8:32 pm
Post
by azzatdi » Sat Oct 22, 2011 9:04 am
That's the same as lowering a mk1!
Looking good
vagnostics_ltd
Post
by vagnostics_ltd » Fri Oct 28, 2011 10:20 pm
2.5" Downpipe with the DPF removed ready for some Pendle tweaking
azzatdi
Post
by azzatdi » Sat Oct 29, 2011 11:25 am
very nice mate did you make it?
if not how many pennies?
vagnostics_ltd
Post
by vagnostics_ltd » Sat Oct 29, 2011 1:34 pm
£140 from PP Tuning in Louth
I have an update for later aswell for another addition to the Caddy mods
vagnostics_ltd
Post
by vagnostics_ltd » Sat Oct 29, 2011 5:01 pm
minibikepro31
Posts: 989 Joined: Wed Mar 10, 2010 10:13 pm
Post
by minibikepro31 » Sat Oct 29, 2011 6:13 pm
my s3 brakes feel like they are going to throw me out the windscreen god no's what there going to do
also with the dpf do you need it mapping out or do you need new software? Also what BHP gain do you get from it?
Looking good by the way.
martin
minibikepro31 on Sat Oct 29, 2011 6:30 pm, edited 1 time in total.
I N T H E B O O S T !
vagnostics_ltd
Post
by vagnostics_ltd » Sat Oct 29, 2011 6:26 pm
Martin it would need mapping out to stop the ECU feeding fuel into the exhaust for re-gen
If we get an RR day off the ground take mine for a spin but im sure the graph & figures is going to talk for itself
minibikepro31
Post
by minibikepro31 » Sat Oct 29, 2011 6:33 pm
matt_tdv6 wrote: Martin it would need mapping out to stop the ECU feeding fuel into the exhaust for re-gen
just edited my post. what sort of gain BHP wise do you get? also anyone know if a 55 plate tdi would have one as i have seen somewhere that its posible they will not as they was made a legal requirement in 2006?
vagnostics_ltd
Post
by vagnostics_ltd » Sat Oct 29, 2011 7:01 pm
Your best bet is to speak to Martin at Pendle Performance
He's that confident he invited other tuners to a rolling road day on the T5 forum and as yet i dont think this has happened
dooka
Posts: 1410 Joined: Sun Feb 14, 2010 6:39 pm
Post
by dooka » Sat Oct 29, 2011 8:37 pm
You need to swap your brake crossover pipes, from top to bottom. Looking very sweet..
Splitpin
Post
by Splitpin » Sat Oct 29, 2011 8:50 pm
Yep the caliper is on upside down, if the pistons are of different sizes they need to be the correct way round.
vagnostics_ltd
Post
by vagnostics_ltd » Sat Oct 29, 2011 9:11 pm
You eagle eyed people
It was only mocked up to see how the wheel sat & to check clearances etc.
I also couldnt wait to take a picture to get uploaded
The old caliper is still attached if you look as the rubber brake hose is still connected
vagnostics_ltd
Post
by vagnostics_ltd » Wed Nov 02, 2011 8:34 pm
My old D3...Ive found a fellow D3 owner in Splitpin now
