My ex British Gas conversion
- BradleyB
Re: My ex British Gas conversion
Some great work in cold conditions
Well done fella
Well done fella
- robblowen
@BradleyB Cheers man, trying to tick off little jobs when I can. Just been too busy for too long!
- robblowen
Finally finished wiring in the split charge system, next to get the roof lining and lighting done in the back!
- robblowen
Had a go with some simple coding jobs as well, managed to activate needle sweep, door warning lights and deactivate PWM on the LED number plate lights.
peely
Just a quick question mate , I have gas van and would like the needle sweep , I tried but it said error on VCDS could you tell me how you did yours
- robblowen
@peely Yes mate, open vcds, ignition on, select control module, select 17 - instruments, select adaptation, click drop down list - select ENG112417 indicator_celebration (towards the bottom of the list), click new value, select active, click do it, click ok, click ok, go back to first screen, ignition off and back on again and admire your handy work! Hope that helps dude.
Gary.8
@robblowen thanks for that..
like @peely i got error when I tried it under staging (I'm using OBDeleven) did it using indicator_celebration and it works
- robblowen
Awesome, glad it helped!
peely
Cheers mate will look tomorrow
- BradleyB
@roblowen
Hi mate too work yet again
Would love the needle sweep but I’d be scared to try coding myself
- robblowen
@BradleyB cheers man, honestly it's really simple to do, that's why I chose it for my 1st attempt! Haha
peely
Mmmm mine still saying error: channel not available, my bcm must be lower than a start linerobblowen wrote: ↑Mon Dec 30, 2019 1:53 pm @peely Yes mate, open vcds, ignition on, select control module, select 17 - instruments, select adaptation, click drop down list - select ENG112417 indicator_celebration (towards the bottom of the list), click new value, select active, click do it, click ok, click ok, go back to first screen, ignition off and back on again and admire your handy work! Hope that helps dude.
peely
What’s staging Gary
Gary.8
- BradleyB
So I can do it via an app no software or computer needed ???
