C Chis
Re: Let the build begin
Post by C Chis »
Managed to salvage a stand-alone RLS mount, sensor and cover out of Golf, bargain at £10
Quick job as I already had a mirror mount one installed following the how to in the tech section
sherwood
Post by sherwood »
C Chis wrote: Thu Jul 09, 2020 10:24 pm A quick picture at dusk, I’ll take some better ones over the weekend after I’ve cleaned the carpets, covered in muck and straw at the moment Image
Hello and congratulations on the caddy.
Excellent work this, what model is the light?
Thank you.
sherwood
Post by sherwood »
C Chis wrote: Sat Jan 09, 2021 3:47 pm New rear lights fitted and coded in using the rather good how to guide in the “how to” section! Many thanks to Doc for writing it up and sharing
And error free LED number plate lights also fitted, straight fit, no mods!
Rear lights and LED’s all next day delivery from travelinlite Image
I would also like to do this job, great!
But unfortunately I am not yet allowed access to the whole forum. :cry:
C Chis
Post by C Chis »
[mention]sherwood [/mention]
Thanks!
The light console came from a Passat, I went down the Passat route as I was struggling to find a salvaged W8 light for sensible money and I really wanted somewhere to store my sunglasses, saves them getting crushed, bent, scratched in the glove box.
You have enough posts now to request additional forum access to the technical sections, get your request in and you should be upgraded within about a week.
It’s well worth the wait!
dawelec
Post by dawelec »
Rear lights look great :D, I wasn’t aware they needed coding in but I guess I will find out when I have full access :shock:
C Chis
Post by C Chis »
Buddy, preface lift van’s are easy to do with VCDS, other ones will require VCP to edit the BCM to achieve the same effect
Worth doing properly as it’s gets rid of the lamp error on the dash and lights up the bottom bar, I’m loving them!
dawelec
Post by dawelec »
Thanks man, mine is a 2013 Caddy Maxi so would I need VCD?
Also is travelinlite a member?
C Chis
Post by C Chis »
No worries!
Yeah, I think you’ll need the BCM coding tweaked to get the bottom bar to light up as a sidelight.
Would be worth posting up to see if there’s anyone local to you that can make the changes
Not seen travelinlite on here.
dawelec
Post by dawelec »
Thanks, I will do, So I guess it’s a company then that you’ve got your lights and LED’s from?
C Chis
Post by C Chis »
Yeah, they seem a good company, genuine parts, not to pricey (my local TPS don’t deal with the public and VW commercial won’t post) and next day delivery.
dallin86
Post by dallin86 »
awsome build mate
C Chis
Post by C Chis »
Cheers buddy, doing my best to make it a comfortable van for mountain biking
C Chis
Post by C Chis »
So, after a wait of almost 11 weeks while my rear bumper has been travelling back and forwards to the paint shop to have a couple of paint faults fixed post colour coding I’ve finally got the bumper protector fitted!
Good coverage and should reduce my chances of scratching the flat section of the bumper when moving bikes, etc in and out!
Finishes off the look I was aiming for at the rear too.
This build just keeps getting better and better mate. The exhaust looks great, as does the bumper......it was worth the wait!
C Chis
Let the build begin
Post by C Chis »
Cheers buddy!
Only problem with bolting new shiny stuff on is that it starts to show up the other small bits that need attention like the small dents and dings!
I’m dreading the day I wake up and add a full respray to my mods list!
