JD's Caddy Build
JD2k
Re: JD's Caddy Build
Post by JD2k »
I trimmed off both of the thin sections left and right of the bulkhead which have the mounting points. A Dremel would probably be more precise but I just used a hacksaw and left enough material to sand and smooth down to a decent finish. The tricky bit is following the contours at front and back of the bulkhead to make sure you don’t cut off too much material.
I then carpeted the trimmed sections and mounted them using the existing holes and bolts.
I found a decent guide posted here with pictures http://forum.caddy2k.com/viewtopic.php? ... 85287b74bc
I didn’t know about the CaddyLife upper and lower B pillar trims you can get from VW till afterwards, but it’s a cheaper alternative looks the part I thinkImage
Dan4da
Post by Dan4da »
Cheers dude
JD2k
JD's Caddy Build
Post by JD2k »
Door cards arrived today! They’re in pretty good condition as per the listing. Once the switches are replaced, lining re-trimmed and given a good scrub they should look goodImage
JD2k
JD's Caddy Build
Post by JD2k »
Still sifting through the part numbers to figure out what motors, control modules & loom I need for electric windows
caddychris2002
Post by caddychris2002 »
JD2k wrote:Door cards arrived today! They’re in pretty good condition as per the listing. Once the switches are replaced, lining re-trimmed and given a good scrub they should look goodImage
Looking good JD really enjoying watching this build take place
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
brooneye
Post by brooneye »
What year is your caddy? I’ve got my door cards off at the minute so I can give you the part numbers of mine and you can check to see if they are ok for what your doing
JD2k
Post by JD2k »
caddychris2002 wrote:Looking good JD really enjoying watching this build take place
Thanks mate still got quite a bit more to do but getting there slowlyImage
JD2k
Post by JD2k »
brooneye wrote:What year is your caddy? I’ve got my door cards off at the minute so I can give you the part numbers of mine and you can check to see if they are ok for what your doing
I’ve got a 2012 caddy so facelift model.. cheers it’ll be good to check against the part numbers that I’ve come acrossImage
Caddy0802
Post by Caddy0802 »
Caddyluv wrote:Behave. £50 stereo surround and 4 door bump strips. Sanded and painted. Image
Where from mate you got a link please ?
Sent from my VTR-L09 using Tapatalk
brooneye
Post by brooneye »
Here’s my modules, you’ll have double check
Passenger
Drivers
JD2k
Post by JD2k »
Thanks for the part numbers much appreciated! Just to confirm, does your driver's side motor have the same part number 1T0959701?
JD2k
Post by JD2k »
Did a quick search using http://www.oemepc.com and found:
PASSENGER
1T0959701 - MOTOR 2005-2007
1K0959792 - CONTROL MODULE 2004-2016
DRIVERS
1K0959793 - CONTROL MODULE 2004-2016
Looks like the control modules will work, but possibly not the motors so I'll have to look further into that one.
JD2k
Post by JD2k »
Had another look.. it seems like the following motors are compatible with those control units for a 2012 caddy:
PASSENGER
1T0959702 - MOTOR 2009-2016
1K0959792 - CONTROL UNIT 2004-2016
DRIVERS
1T0959701 - MOTOR 2009-2016
1K0959793 - CONTROL UNIT 2004-2016
JD2k
Post by JD2k »
Got hold of some touran motors with control units for £20 each.. hopefully they’ll workImage
JD2k
Post by JD2k »
Bit of work done on the centre console.. added an internal USB/AUX port
Then shortened the rear panel.. will be adding a switch panel at the bottom for lights/USB sockets/Voltmeter display running off the leisure battery
