Toffee delights
Marty998
Re: Toffee delights
Post by Marty998 »
Awesome,
I’ll need to sort something out.
I’m thinking on using the r8 handbrake callipers.
Lister79
Re: Toffee delights
Post by Lister79 »
I believe Still Static are looking to produce a kit, so may be worth giving them a call.
Only difference is I think their kit has the 4 pot calliper front mounted and the handbrake up at the back. I’ve had to change my rear axle to enable the 4 pot position that I wanted.
I’m told that in order to get the correct handbrake cable angle it’s the Ferrari F430 handbrake callipers that you’ll need (ref [mention]ToiletTFSI [/mention]). I personally can’t confirm this though as I’m happy enough with how my current setup looks, so haven’t looked any further into it.
Marty998
Re: Toffee delights
Post by Marty998 »
Perfect thanks for the info much appreciated.
Marty998
Re: Toffee delights
Post by Marty998 »
What made you go for a caddy maxi rear axle?
Lister79
Re: Toffee delights
Post by Lister79 »
I haven’t gone for a maxi axle, I’ve fit an early axle as they have a bolted stub axle. I needed the extra fixing points these have for my calliper mount.
Mark.five
Re: Toffee delights
Post by Mark.five »
Really detailed build and well documented. Very helpful to those looking to modify their own 🙏
Lister79
Re: Toffee delights
Post by Lister79 »
Thanks for the comment and for taking the time to look through my build. I’m pleased you find it useful, thanks again.
Lister79
Re: Toffee delights
Post by Lister79 »
So it begins.......
Interior stripped out ready for when the new wiring goes in; also a good time to tidy up the additional looms that have been added over the last couple of year.
I had pre-wired it so I wouldn’t have to do this, but unfortunately to solve a couple of the start/stop fault codes (my van isn’t start/stop) I need an extra couple of wires so may as well start again. Plus I can now use the correct colour wires I removed from the donor loom.
brooneye
Re: Toffee delights
Post by brooneye »
You must be able to strip that in your sleep by now. Watching this with interest so keep it coming
Beaker2135
Re: Toffee delights
Post by Beaker2135 »
Wow it looks scary when someone else is doing it :lol:
Been looking forward to this and will be keeping an eye on progress for as long as it takes
Lister79
Toffee delights
Post by Lister79 »
[mention]brooneye [/mention]hopefully this will be the last time the dash needs to come
[mention]Beaker2135 [/mention]I think it looks worse due to how the additional looms a lying, once everything is in the main loom it shouldn’t look so bad. It was scary removing the trims from the freshly trimmed dash though
Hopefully I won’t annoy people too much with the updates once I start my leave from work.
Re: Toffee delights
You won't annoy anyone with updates on this, most will be relieved it's not them.
I for one can't wait.
Toffee delights
You won’t annoy me with updates either mate. I think it’s genuinely amazing that people are brave enough to undertake work like this. I know I’m not!
I hope it goes smoothly mate
Azz03
Re: Toffee delights
Post by Azz03 »
I can third that you won’t be annoying me with them either. I always look forward to seeing what’s new on your mod list every time your name pops up haha. Keep the updates coming [mention]Lister79 [/mention] can’t wait to see the progress
Sean1066
Re: Toffee delights
Post by Sean1066 »
You won’t be annoying me either I shall definitely be looking forward to seeing the progress I will probably be annoying you with questions.
Especially with the wiring and where it all goes. 😉
Caddy maxi 3.2 VR6 EX BG
My build thread
