Sound deadening
Flog_TSC
Sound deadening
Post by Flog_TSC »
Seeing as I can’t get onto any of the main stuff on this forum I’ll stick this hear what have everyone used for sound deadening seeing as there is so much to choose from
Temu ?
EBay ?
Dodo Matt
Vandalised and I’m sure there is a few more
Any advice and how many sheets for a maxi ?
Scotscad
Re: Sound deadening
Post by Scotscad »
Hi. I got sheets of dodo mat from ebay. Plastic bottle insulation from b&q and carpet from vandalised thru ebay again. Used a lot of dodo mat but i did cover everything. I bought a box of 20 sheets to start with as i did it in stages and so i wasnt left with too many unused. Not sure if iv used 2 or 3 boxes to date but iv got half a box left and just the front doors to do. Hope this helps.
Flog_TSC
Re: Sound deadening
Post by Flog_TSC »
Scotscad wrote:Hi. I got sheets of dodo mat from ebay. Plastic bottle insulation from b&q and carpet from vandalised thru ebay again. Used a lot of dodo mat but i did cover everything. I bought a box of 20 sheets to start with as i did it in stages and so i wasnt left with too many unused. Not sure if iv used 2 or 3 boxes to date but iv got half a box left and just the front doors to do. Hope this helps.
Yeah great hep so far I bought that stuff from bnq and wanted to get everything from vandalised in one go but maybe I’ll do what u have done did u do the cab aswell ?
Scotscad
Re: Sound deadening
Post by Scotscad »
Yeh the floor and the roof so far. Just the doors to do then its all done. I did everything i could cover in dodo mat. Inside the barn doors, the rear floor, all the sides and the rear roof. Then carpeted the rear and made a roof panel with leds round the edge and led spotlights in the roof panel.
Flog_TSC
Re: Sound deadening
Post by Flog_TSC »
Scotscad wrote:Yeh the floor and the roof so far. Just the doors to do then its all done. I did everything i could cover in dodo mat. Inside the barn doors, the rear floor, all the sides and the rear roof. Then carpeted the rear and made a roof panel with leds round the edge and led spotlights in the roof panel.
Sounds good yeah I think doing it in sections has got to be the way
Re: Sound deadening
I did inside the back doors, the roof, the arches, the floor and every little gap I could find of single skin I could get my hands into. I ended up using 80 sheets.
Got it off eBay for around £65
https://ebay.us/m/kItmwv
Scotscad
Re: Sound deadening
Post by Scotscad »
Yeh thats just about the same as what iv dont to mine. Went a bit ott but its done now and im not removing it lol
Flog_TSC
Re: Sound deadening
Post by Flog_TSC »
gazza31112 wrote:I did inside the back doors, the roof, the arches, the floor and every little gap I could find of single skin I could get my hands into. I ended up using 80 sheets.
Just Orderd 40 sheets for now nice one I best get cracking
Flog_TSC
Re: Sound deadening
Post by Flog_TSC »
Scotscad wrote:Yeh thats just about the same as what iv dont to mine. Went a bit ott but its done now and im not removing it lol
I’ve got a feeling once I start I won’t stop haha
Scotscad
Re: Sound deadening
Post by Scotscad »
Id say for u to get a small roller to help fit the sheets. I wish i had.
Re: Sound deadening
Agree, they slice your hands to pieces...
Jase14
Re: Sound deadening
Post by Jase14 »
Got all mine from Harrison’s trim including carpet, roof lining, moisture barrier and 15 tins of spray adhesive which I have used 😱 but that’s on a maxi 80 plus sheets of dodo mat too
Flog_TSC
Re: Sound deadening
Post by Flog_TSC »
Jase14 wrote:Got all mine from Harrison’s trim including carpet, roof lining, moisture barrier and 15 tins of spray adhesive which I have used Image but that’s on a maxi 80 plus sheets of dodo mat too
What ones the moisture barrier ?
So am I right in saying use the recycled plastic in all the cavity’s then use the sound deadening then the floor use the rolls of foam with a silver foil then just carpet everything after ?
Jase14
Re: Sound deadening
Post by Jase14 »
Yes use that to fill the cavities with alloy foil tape over all holes, dodo mat, get a heat gun and warm the sheet first, then roller down with a plastic decorating roller then I used silver backed foam sticking down over the top and finally carpet. Get some clips to hold it roughly at the right height start in the middle and work outwards
Jase14
Re: Sound deadening
Post by Jase14 »
Also tape down all edges with the alloy tape before carpet
