Cassie the Ex BG Camper
LouisNaylor
Post by LouisNaylor »
So having followed the forum for a while, and taken inspiration from many of your guys builds. I'd thought I'd come on and document some of the progress that I've made.
The van came from a local dealer, with the previous owner being a decorator the van was in a right state...
First step as always was to strip everything down and give a good deep clean
It was then onto sound deadening, highly recommend DodoMat, very easy to work with.
For insulation I opted for B&Q recycled bottle and DodoMat Closed Cell.
I then cut down the bulkhead to cover the gaps by the sliding door (these will later be carpeted).
With moving house & a holiday in the alps to climb Mont Blanc progress at first was a little slow...
Chose to pay the extra to get the windows fitted, didn't want the risk of any leaks.
Next on my list was electrics, have been lucky enough to work with Vunked, who made the whole process very easy. Using a 105aH leisure battery, 30a DC-DC charger and solar which I'll come onto in a bit.
Wanted to keep them out of the way, so with some careful planning managed to fit everything behind/ under the passenger rear footwell.
Finished off the roof insulation next.
This weekend was tasked with fitting the solar panel, I saw on a Facebook forum that you could route the cables in via a grommet on the front side of the sliding door, this saved me with drilling any holes (may be a little less aesthetic but works a treat). Opted for a semi flexible solar panel as I may need a roof box for some trips.
Then finally for the progress so far I started on 12mm batons to attach the ply floor down and finished off by insulating in between (my OCD will aluminium tape any gaps tomorrow)...
LouisNaylor
Re: Cassie the Ex BG Camper
Oh and for anyone that has Instagram that would like to keep up with hiking, camping & conversion adventures @louis.naylorr
jakemcc97
Post by jakemcc97 »
Progress looks good, that electrical setup is really tidy. Nice to see another climber here, feel like these vans are perfect for it!
Gave you a follow on Insta, looking forward to seeing more progress!
Jake's Caddy Camper Build
Silver 2017 2.0 TDI Highline
Post by stu_b »
Hi louis naylorr
Looks like you've done a clean build
Very tidy and thorough
I am interested to learn / see pics of the grommet for the solar cabling in the sliding door area
Care to share
Tks
Stu
