Well, it only took 3 months after I sold my Caddy before I got another one
If I brake hard enough for the ABS to activate (and the problem only occurs if the ABS activates, no matter how hard or gently I brake), the next time I push the brake pedal it travels a very long way before anything happens! The brakes work just as well as normal when they do engage though. I thought I'd fixed it when I replaced the unevenly worn front discs and pads and bled the hydraulic system, but apparently not. The brakes are normally very fierce and work well, it goes in a straight line under hard braking and the handbrake's working fine. No grabbing, either. None of the calipers are sticking and it's sailed through its MOT like it (I wasn't aware of the problem at the time).
After parking the van up for a while, or pushing the brake pedal a lot, it goes back to normal (until the ABS kicks in again). I haven't tried bleeding the ABS unit itself yet.
Has anyone encountered this before?
Thanks in advance
